OctaneRender for Rhino 3.03.2 [OBSOLETE]
Hi Andreas. Welcome back. For Network Rendering you are right - Standalone 2.23.1 is not available. It will do a build of the plugin with Octane 2.23.2 so you can use the latest Standalone release.
v-cube
thanks Paul !
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
2.23.2.37
- Compiled with Octane 2.23.2
v-cube
Hello Paul,
sorry but I still don't get it...
when I go to Board index / octane licensed customers / development releases the latest version seems to be 2.22.2
am I missing something?
best
Andreas
2.23.2 is in a different forum - sorry. http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
v-cube
Ahhh - now I see -> sorry and thanks for the hint :-)
Tipperz
Forgive me if this has been answered already but where can I download the latest Network Render Slave and demon's? Our GPU server is now offline!
Thanks..
Win7 pro 64 / i7 4930 3.4 6core / 2x gtx 680 4gb / 32gb DDR3
2.23.2.40
- Fixed a number of issues introduced in 2.23.2.39, including Cuda errors when rendering block instances
- When using an ORBX as a proxy, if there is not a single disconnected geometry node in the proxy scene, the plugin will use the first Geometry Out node, and if that is not found if will use the node that is connected to the Mesh pin of the Rendertarget
2.23.2.39
- Added Render Layer field for Geometry items with Live Update enabled. This will allow Shadow Passes to be used (remember to enable Kernel->Alpha Channel when doing this)
Pls note that this version required Rhino SR11.
Humpti
Hi Paul,
as the Object ID probs are solved I will continue here in this thread.
Loading my scene I have no errors, but if I explode the people-block I get some new errors.
If I take these people and create a new block of them I get a new error. Please see the screenshots.
As you already have the scene I didn't attach it again. Simply explode the group of people - render - and recreate a new block of them and render again.
One other small bug I noticed: When I load the scene I can not select the render passes. I have to deselect a pass and reselect it first.
Besides that the object id works fine now :)
Thanks a lot.
Philipp
Return to “Rhinoceros 3D”
