cheap fish eye lens on the thin lens camera
nuno1980
bepeg4d wrote:Hi,
i have used the easter vacations for rendering the PMC version of the pool as promised, here is the result after 19h:52':24" for 16000 sampling:
and here is the PT version with the same settings and sampling level but in 04h:23':37":
and here is what happen under water in PMC:
Thank you! PMC is clearly better option. :) But 16,000 samples/px isn't good enough because the caustics are darker and/or more noise than real-life.
For your 1920x1080, minimum 40 to 60 kS/px for very good caustics, sorry. ;)
Minimum samples per pixel for very good caustics (no "caustic blur") at 5k rejects and parallelism 1, if your scene is running sun light (our solar system):
--> 1002x602 pixels: 150 to 200 kS/px
--> 1920x1080 px: 40 to 60 kS/px
--> 3840x2160 px: 10 to 15 kS/px
Can you understand well? :)
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ViewSonic XG2431 24" :D
more than 24h is not an option for me ;)
if i have time i prefer to render the PT version for the same ammount of time of the PMC version for a better comparison
but is difficult for me to find the time for this, i think
ciao beppe
p.s. the scene is lit with a modified HDR.
nuno1980
Ok. But if the sun size is "thin" (=real) then PT makes very hardly good caustics.
I had rendered image during 73 hours (3 days but few pauses with hibernate (Windows)) at PMC kernel but it's normal. :) - I've sent to PM. :)
Caustics at PT
i7-12700KF
32GB DDR4@3600
Tugpsx
bepeg4d wrote:more than 24h is not an option for me ;)
ciao beppe
Very nice work. Thanks for sharing results. Do you mind sharing the settings for the fisheye-box as well as the camera adjustments.
So far we gather that the material is specular and added to a 10x10x1 box/plate that's placed before the camera.
Adjustment to IOR and focal length along with dispersion to get the real lens look.
Tugpsx wrote:Very nice work. Thanks for sharing results. Do you mind sharing the settings for the fisheye-box as well as the camera adjustments.
hi tugpsx,
sure, i wiil prepare an orbx to shere as soon as i can ;)
ciao beppe
hi,
here is a fisheye lens scene in c4d, ocs and orbx format.
in standalone you need to copy the camera position in the placement node of the glasslens or use the marcus Lua script for the foggy inverted sphere. With an integrated plugin it's more easy and you can navigate the scene with fisheye in real time ;)
ciao beppe
FishEyeCornell(bepeg4d).zip
(152.62 KiB) Downloaded 285 times
resmas
bepeg4d wrote:hi,
ciao beppe
thanks for sharing mate. ;) ;)
cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
Tugpsx
Thanks more new toys to play with
joeycamacho
Thanks for this. One question - is there any way to remove the small cube from appearing in reflections on other objects, while still being able to retain the fisheye effect?
Freelance Motion & Graphic Designer
Cinema 4D R19| Win 10 Home 1803 | 4X GTX TitanX 12GB Maxwell | Intel Core i7 5930K 3.5GHz | 48 GB DDR4 -2133 RAM
Tugpsx
Are you referring to the mesh light? Light source can be adjusted
