Version 2.22.2 - TEST3 - Updated on 03.04.15
Elvissuperstar007
Hello! I find a bag: the animation of native noise shader works only on polygonal objects and mode - send all scene's data. The function "resend only update objects" with noise animation doesn't work, which unfortunately increases render time. For example, if I have mograph + plane + native noise shander (with animation) in displacement chanel, in this situation I have to render scene in mode "send all scene's data" which increase render time - x2. Examples, you can find in the folder: https://www.dropbox.com/sh/aqzfn5h0um3t ... 1T8ha?dl=0
Elvissuperstar007 wrote:Hello! I find a bag: the animation of native noise shader works only on polygonal objects and mode - send all scene's data. The function "resend only update objects" with noise animation doesn't work, which unfortunately increases render time. For example, if I have mograph + plane + native noise shander (with animation) in displacement chanel, in this situation I have to render scene in mode "send all scene's data" which increase render time - x2. Examples, you can find in the folder: https://www.dropbox.com/sh/aqzfn5h0um3t ... 1T8ha?dl=0
it's not a bug i suppose. If you don't make any key, materials will not trigger any update message. You should create a fake keyed parameter to help it.
Elvissuperstar007
Unfortunately, it still don't work's. With fake key on noise animation speed patameter or many keys on other parameter's of noise shader or with key on object or with key in octane diffuse (or other) shader. It still work only in "Send all scene data"
Elvissuperstar007 wrote: Unfortunately, it still don't work's. With fake key on noise animation speed patameter or many keys on other parameter's of noise shader or with key on object or with key in octane diffuse (or other) shader. It still work only in "Send all scene data"
should i check the which scene from your folder?
Elvissuperstar007
yes, please - https://www.dropbox.com/sh/al3tliid3nav ... 0rGFa?dl=0
Here, this is my working sample.
disp.zip
(100.84 KiB) Downloaded 327 times
Elvissuperstar007
I got it! Thank you very much!)
insertcoin
Hi, i've some trouble with layer mask when i render to picture viewer.
the result is incorrect.
have some1 else noticed that?
Seems he stop calculating after 31 passes
Thanks.
INSERTCOIN
C.so Europa 1334
16166 Genova/Italy
http://www.insertcoin.tv
insertcoin wrote:Hi, i've some trouble with layer mask when i render to picture viewer.
Thanks.
Version? Have you watched the passes tutorial?
insertcoin
i've seen that in 2.16.2 there is no voice under render setting for separate id layer mask.
So after watching tutorial found here : http://inlifethrill.com/trainings/octan ... ayer-mask/
i tried 2.22.2 test3 where menu render pass layer is present.
And yes, i've seen all possible tutorial.
I'm trying for two hours now.. but i can't see how to... and we are close to deadline..
thanks
Scene_bug.zip
Here the cleaned scene
(85.81 KiB) Downloaded 312 times
As you can see, two renders are different for layer id also
INSERTCOIN
C.so Europa 1334
16166 Genova/Italy
Return to “Releases”
