Florida Sofa [fixed wrong color profile]
sadece
Thank you guys for your kindly posts. I'm glad you like. I did a mistake with forgetting to convert sRGB now fixed. Hope you still like :)
ChrisVis wrote: Or did you mean 1h 20min? :)
Unfortunatelly, i meant 1h and 20min. but still not too bad for this resulotion i guess :roll:
glimpse wrote:You need caustics!!!
It doesn't look real!!!
Jokes asside, I hope it's not full interior..
'Cos your times are too good for this resolution =)
hehe and what about the mirror? :P btw i'd like to say it's a closed room but as you guessed it is not :)
And i tried to answer your questions about setup. hope i could.You may notice plactonic bulbs. in past, I've noticed better shadows by this way after some of tests.
I'll answer new questions with pleasure if you have some.
Thanks for watching..
http://www.sadece.com.tr
i7 990x // 12GB Ram // 2x Titan X + Titan + 780 // Octane for C4D // Win7 x64
WhaleHunter
Very sneaky sadece. Good idea for faster render times.
nuno1980
Seems true photorealism because PT is enough due to ambient light (= great area light -> shadows blurry and little visiable caustics blurry). :)
I like it! :D
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
ChrisVis
Hi Sadece,
thank you for your insights.
The Rendersettings are quite optimized for speed. I figured out, that GI-Clamp of 1 gives that high contrast crisp look. If you go with 2 or 3 there are noticable differences in the light-diffusion, at least at my test scene.
Anyway...
Did you ever test Direct Lighting GI Diffuse Render Kernel?
I did a lot of tests and found out, that there are only slight differences between your PT settings and the following DL GI_Diffuse Settings (mainly in the shadows and color reflections).
Maybe you might give it a try with this scene and post a comparison? I have seen speed improvements of about 30-40%, with very little visible differences, at least at my test scene.
Because you know: Its all about true Photorealism, but sometimes more about Speed and Photorealism ;).
Greetings,
ChrisVis
C4D R15 - C4DOctane 4.0 | Win7 64 | NVIDIA 417.22 | EVGA GTX 980 Ti SC | EVGA GTX 780 Ti SC |EVGA GTX 780 Ti SC
i7 4930K 6x4.3GHz OC | 64GB | ASUS P9X79-E WS
+ Netstor Turbobox 250A | 2x EVGA GTX 780 Ti SC + 2 x Palit GTX780 Ti 3GB | all watercooled
pxlntwrk
hi,
great one !
a bit foggy, and scratches on the picture are uneeded for my taste
and you ShOULd use PMC of course :mrgreen:
pxlntwrk.net
huyrua811
wow ,can't believe it :| it perfects
sadece
nuno1980 wrote:Seems true photorealism because PT is enough due to ambient light (= great area light -> shadows blurry and little visiable caustics blurry). :)
I like it! :D
Hey Nuno1980 is that really you or your account here has been hacked ? cant believe you liked and not find a problem with it. =P i'm joking :)) thank you!
ChrisVis wrote:Hi Sadece,
Anyway...
Greetings,
ChrisVis
Hi,i agree with you about GI clamp.i didnt have enough time to play with setting for this image. all done and rendered in 10hours. so i went with my safest settings :) (noise free)
i used to use DL - diffuse. and still usually compare just before final render. in most situation it has no big render time advantage when use same diffuse depth value in both kernels. but with your setting 1 will cause too darker image i guess. i'll test and share the result with your setting as soon as i have free time. the best is both speed and realism :)
pxlntwrk wrote:hi,
great one !
Thank you Pxlntwrk. yeah i tried to achieve a vintage mood in post. but could get what i wish exactly. thank for the PMC tip :)
huyrua811 wrote:wow ,can't believe it :| it perfects
thank you so much:)
glimpse
sadece wrote: Hey Nuno1980 is that really you or your account here has been hacked ?
=DDD..
Lewis
Looks great, everything is nice and you catched that vintage look/mood perfect (even without PMC ;)).
BTW i wonder what's up with Octane and wall thickness, why does it have so much issues cleaning up interior when it's "full room" and works so nice in this "paper thin" walls ? Is there any techical explanation/reson for this or ? thanaks and sorry for question/hijack :).
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
sadece
Thank you Lewis
it's ok.. no hijacking.i wouldnt mind even it was. we all are here to ask and get answers:)
about wall thickness i cant speak much bcos dont know techical details. i have read it as tip somewhere in the forum. and noticed the same tip in some vray interior setups too you can find in internet easily. and i just gave a try. honestly didnt see a big diffirance. i ll test more when have time to. maybe someone here may explain better in technical way.
actually there is no issues in closed setups too. just need more time to calculate since octane is an unbiased engine. think in vray bf/bf with very high subdiv value. could vray handle it in short time? i agree Octane is not the best for interiors but i believe in Octane team also our c4d dev. Ahmet. this is why i am here. by the time and having more experience with Octane i see my renders getting better day by day. maybe i changed the topic little bit but never mean to compare engines. just my two cents.
Cheers
Hüseyin
