Feature requests in the Maya plugin
Moderator: JimStar
The camera mapping projection !
							Laptop HP 8760w, I7, 16Go ram, Quadro fx3000m, Maya 2014, Octane 1.20a. Vimeo: http://vimeo.com/ciboulot/albums
						- Jolbertoquini
 - Contact:
yes also the render mip_render_subset option each a lens option on mentalray would be good to have similar. some info about that http://www.nvidia-arc.com/fileadmin/use ... uction.pdfciboulot wrote:The camera mapping projection !
And light path expressions...
http://blog.irayrender.com/post/7694889 ... xpressions
Or just Light pass integrated on Maya plug...
The most import have a proper maya scene exporter to orbx standalone scene.
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
yeah totally, along with the feature to control glossy and gi ray bouncing / emission on a per-object basis (like cast no reflection, primary visibility and other render attributes)ciboulot wrote:The camera mapping projection !
- abstractmedia
luk4 wrote:batch render on network with maya open
You can do this, you just can't have the same scene open. What I usually do is save out my render scene as a different name if I want to continue working on another section.
DOCUMENTATION
This is important - the Maya plugin documentation is really out of date - like years ago out of date. I keep having to dig through the forums and try to figure out which search term to use to figure out how something works.
Naming layers is not comfortable in some cases  example - (***norm_001.tga) not possible with octane instead (***_001_norm.tga) is apear.
							5x-Gtx1080 Ti+ 4x-Gtx 780 Ti, 2x-Xeon 2687W, 192Gb Ram
						I would really like to have the option to output the passes to separate directories.
It would also be very nice if the pass-name was not at the end but before the framenumber in the filename. That would save me the agony of sorting and renaming the rendered sequences again and again.
Win 7 x64 | i7-4930 | 64gb | 4x gtx 780Ti 3gb
