OctaneRender™ Standalone 2.21.1
smicha
abstrax wrote:
Elvissuperstar007 wrote:projection does not work in the bump and displacement
Standalone 2.21.1
Displacement mapping supports only UV projection. Bump mapping supports all projections. Could you send us / post the scene with the incorrect projection of the bump map? Thanks.
Marcus,
I had the same issue with one of my scenes - material was glossy, with box mapping and world space and bump was not working.
Goldorak
AlexMakhov wrote:
abstrax wrote:
smicha wrote:Another question: if I have e.g., 5GB of obj files and 4GB of textures and let's say a titan can allocate up to 6GB - will octane load 5GB of objs and 1GB of textures to vram and excessive 3GB of textures to RAM?
In principle yes, but the maximum amount of geometry memory you can use is currently limited to ~19 million triangles, which will use about 3GB of memory and a 5GB OBJ file will use a lot less memory than 5GB on the GPU.
When this bug (19 million limitation) will be fixed? I cant finish my current project :-(
#GTC15
Elvissuperstar007
Standalone 2.21.1
https://www.dropbox.com/s/06mlk7bvjdgr3 ... .orbx?dl=0 here is the scene
grimm
I'm have a problem, or more of a minor irritation that is. :) When you change a node type or load a different texture into a node the node collapses in the inspector. It would be nice if the nodes stayed open or close as they were.
BorisGoreta
I need to comp rain on top of a real footage and for that I use layers, but mask layer renders without motion blur and there is no good rain without motion blur.
FrankPooleFloating
Boris, I have done rain comps a bunch of times. Doing it as straight spec & reflections over flat black (or invisible to camera, with blk bg) copy of scene and rendering with no alpha in LW (with moblur and instance splashes etc) and then comping in AE as Add or Screen (or a combo of both) has proven to be realistic enough for my needs...
mikinik
Hi guys! When motion blur to work on the mesh from realflow? You can make it at least realflow stitched alembic file?
Such file in link - https://www.dropbox.com/s/qx1ojuaf6l661 ... c.zip?dl=0
r9 3900x/64Gb/2070s/2070/win10x64/3dsmax2021
voon
Hm ... I keep getting all 3 GPUs failed when loading some scene .. is it too big? How can I check?
Zay
voon wrote:Hm ... I keep getting all 3 GPUs failed when loading some scene .. is it too big? How can I check?
GPU-Z
http://www.techpowerup.com/downloads/SysInfo/GPU-Z/
voon
tried again with a very small scene and two GPUs would go fail. Driver is the newest Nvidia driver. Usually, I had no issues.
