A classical bathroom
glimpse
PAQUITO wrote:
glimpse wrote:The Only question, how You manage to remove that tint (usually blueish)?
I guess you are talking about the blueish tint you get in DL when using the sky environment. In this scene I use a blue emitter combined with a white environment. Also I use to make a white balance at the end (with the white point tool).
Yeah, exactly 'bout that!
Thanks for tip, Paquito =)
PAQUITO
Hey resmas, what is that GI clamp thing you are talking about?
AMD FX8350 8 cores. 16GBs RAM
GTX690
Win8 64.
resmas
PAQUITO wrote:Hey resmas, what is that GI clamp thing you are talking about?
Hi mate, the GI Clamp its a option in PT kernel. Most of the times I use DL (AO and Difuse) but sometimes I need Path Tracing and in there we have the GI Clamp that gives faster results.
If you want I can remove the images I posted earlier, this is your post so just let me know if you want them removed.
Once again thx for your file. I will try to post a shoot.
cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
PAQUITO
Ok, that´s for the PT kernel. Thanks for the info.
Don´t worry about the images. This is not "my" post, it´s for everyone to check out :)
GTX690
Win8 64.
heartlessphil
futoryan wrote:
Seekerfinder wrote:Paquito has shown on many occasions what is possible with DL. I am always impressed with the speed-quality ratio he achieves with this approach. DL is always good for iterative work, but if we can use it for production, so much the better.
Seeker
I agree. It's all about the speed to quality ratio.
I use PT and pmc for my personal work when I have time for longer renders, but in a production environment fast turn-around is very important and time is a rare luxury. DL is often my goto kernel because it produces pleasing results very quickly. Clients don't care as long as the image looks good, and ultimately, they have the final say.
Of course, that's just my opinion and I could be wrong.
Do you really have these kind of tight deadlines where you really can't afford a PT/PMC render? I mean, AFAIK, we have pause/resume render, batch render, etc. You don't have to send your client a full clean noise-free render for every change you make. After 2 mins the render gives you a good idea of what the final image is going to look like. Then, you let it render overnight... in 48h straight you could get 5 x 10-hours high quality renders. I don't have much experience yet but I struggle to understand how can they not give you a day or 2 to do the final renderings. How much time do you have to make a typical 5-10 images project?
resmas
heartlessphil wrote:
Seeker
Sometimes i have 8 hours to model and render....so DL is the answer.
Cheers
Resmas
nuno1980
PMC kernel@22-diffuse,@40-specular depth running GTX 670 (until buy GTX 980 xD)
Imager:
-dscs315_2
-exposure 2
-gamma 1.6
:D
Do you like my image? ;)
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ViewSonic XG2431 24" :D
PAQUITO
Yes, I like it, and the image is good. Now, you spent 15 minutes versus something like 1 minute or less for my image. And putting them side by side, I can´t see why I must consider the PMC version better than the DL version. To me are nearly identical (appart from the color balance and exposure).
GTX690
Win8 64.
nuno1980
PAQUITO wrote:Yes, I like it, and the image is good. Now, you spent 15 minutes versus something like 1 minute or less for my image. And putting them side by side, I can´t see why I must consider the PMC version better than the DL version. To me are nearly identical (appart from the color balance and exposure).
I can see the differences between your image and my image (not color balance nor exposure):
your: no caustics very blurry by color... -> bit fake photorealism (bit cartoon)
my: caustics very blurry by color... -> true photorealism
Should study about the differences between kernels (DL, PT...) - here and search "kernel".
If you use PT or PMC kernel then should modify the model(s) of material(s) and/or color(s) of material is(are) incorrect(s). ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
glimpse
nuno1980 wrote:I can see the differences between your image and my image..
Nuno, we all see that..but that's not the point.
The client, who pays money, don't care about that difference. So, why to waste more time (taking it from family, kids wife, etc..) when You can spend less time at work or do more at the same time? =)
