Blender for Octane, camera rotates slightly on final render?
crazycourier
I'm running into an issue where my final render inside Blender for Octane gets rotated slightly.
I tested this with a exact duplicate scene in cycles and the issue is not present. I'm using the latest download of Blender for Octane (downloaded yesterday).
This is the viewport render, which is correct.
Viewport render
Viewport render
This is the final render, which the camera is rotated about 2.3 degrees.
Final render
Final render
This is a comparison between the two (the red being the final).
Comparison
Comparison
I've checked everything I can think of. Perspective distortion in the camera settings had no difference.
Anyone run into this problem before?
Windows 7 64bit, Intel Core2 Extreme CPU X9100 3.06GHz, 8 GB Ram, Nvidia Quadro FX3700M.
JimStar
Thank you for report.
Could you give me this scene?
crazycourier
Jim, I sent you the project file. Have you had a chance to take a look at it. I've spent more time on my end, but no luck figuring out the issue yet.
JimStar
I'm still in vacation (as I was when I was answering you previously)..;) Will be able to look at it after I get back into the office...
igor73
I have also had this problem. Had to cut the sequence 10 frames or so short to get rid of it while editing. This was on version 1.55 though Just recently upgraded so 2.0 + so don´t know its still there.
JimStar
Just found and fixed one bug related to this. So, should be OK in next version.
crazycourier
When do you think the next version will be available? This is basically keeping me from using Octane for this project I'm working on.
crazycourier
Any word on when the next version with this bug fix is going to be released?
Return to “Blender”
