Octane exporter for C4D version 0.03
Stephan3D
abstrax wrote:
Stephan3D wrote:@ ribrahomedesign
you must "bake" the texture and object in C4D and then export
look at my picture in top of my post, it is a uv texture in octanerender
there is another way to export uv?
Stephan
Yes there will be with 0.04. I'm trying to automatically convert the non-UVW mappings to UVW mapping. This will have a lower precision, as you can't 100% replicate for example a spherical mapping with UVW mapping, but if the mesh resolution is high enough it should work good enough. I hope 0.04 will be available in the next 2-3 days.
Cheers,
Marcus
what shall I say, perfect, thumbs up :D
Thank you very much
Windows 7 64bit, Asus 9800GT, Cinema 4D 10, Zbrush 4
abstrax
Hi all,
here is a small progress update: I have now the automatic splitting working. I have also added a framework that allows to plugin different texture mapping conversions, which will then take care of texture scale and offset and all the other texture parameters, that can be converted to UVW. I will probably release that version tonight (NZ time) and do the UVW conversion after that release, to let you play with it and test it as soon as possible.
This is a test scene mantra sent me, exported with the new version just before I went to work:
Cheers,
Marcus
mantra
You did it, man!
Release will be today?
MY WORKS
Cinema 4d | Win7x64 | 450gts
russian octane community
http://vk.com/octanerender
abstrax
mantra wrote:You did it, man!
In 10-12 hours. Have to work first and then do some other stuff. But then: Yes :)
Cheers,
Marcus
nuverian
Thanks a bunch for this plugin. It's way great allready.
http://www.nuverian.net
nuverian.deviantart.com
i7 920 2.66, 6G RAM, GTX 660 Ti, Win7 64x.
Vincent
So, today should be a great day ! :P
Win7 x64 - Intel Core i7 920 (2.67 GHz) - Geforce GTX 285 - 12Go RAM
www.wipix.fr
useruser
once again: Thank you so much abstrax! :)
Workstation: Win 10 PRO 64 bit, 3,4 GHZ ,6-cores, 64 GB RAM , 4x RTX 2080 Ti
1. RenderSlave: Win 10 Pro 64 bit , 3x GTX 980Ti
2. RenderSlave: Win 10 Pro 64 bit 2x GTX 980 Ti
lassinger
thanks from me too!!!!!
http://www.larsnaglerworks.com
http://www.behance.net/LarsNagler
http://cargocollective.com/larsnaglerworks
Mac Pro 5.1 :: 3,33 GHz 6-Core Intel Xeon :: Mac Pro Nvidia GTX680 4 Gig :: 32GB :: C4D 13 Studio :: Octane Renderer
OP-1
