Version 2.16.2
OK so I just tried to save out some materials from standalone (v 2.15) again, and save them in the localDB. This results in that c4d closes whenever I click on the "localdb" tab in the liveDB window. I've attached the livedb folder from my prefs folder here.
- liveDB.zip
- (453.92 KiB) Downloaded 299 times
Workstation: Watercooled 4x GTX 780, 1500W Corsair AX1500i PSU, 4930K, 32 GB RAM, SSD and Cinema4D.
Render slave: 4X GTX 780 Asus Strix 6GB, 1200W Corsair AX1200i PSU
hi aoktar thank you for the hard work
i just install the new 2.16 and when i try make new material i get this message
try with 2.16.schodt wrote:OK so I just tried to save out some materials from standalone (v 2.15) again, and save them in the localDB. This results in that c4d closes whenever I click on the "localdb" tab in the liveDB window. I've attached the livedb folder from my prefs folder here.
Thanks. Can you see any files in "res" folder in c4doctane? It says that cannot open or found *.res filesalbehany wrote:hi aoktar thank you for the hard work
aoktar wrote:try with 2.16.schodt wrote:OK so I just tried to save out some materials from standalone (v 2.15) again, and save them in the localDB. This results in that c4d closes whenever I click on the "localdb" tab in the liveDB window. I've attached the livedb folder from my prefs folder here.
Just installed 2.16, erased liveDB folder, saved the materials via. octane standalone 2.16 - still having the same problem.
I cannot reproduce the problem here. Anyone has similar problem? Also i'm uploading a new version with some minor fixes on "localdb". May helps to you.schodt wrote:aoktar wrote:try with 2.16.schodt wrote:OK so I just tried to save out some materials from standalone (v 2.15) again, and save them in the localDB. This results in that c4d closes whenever I click on the "localdb" tab in the liveDB window. I've attached the livedb folder from my prefs folder here.
Also, ORBX import isn't working here either
I've attached the ORBX file I'm trying to open, to this post..
- Is_216.orbx
- (12.54 MiB) Downloaded 320 times
what are you trying? Getting the geometry? It's not possible. Only material import should work but i haven't checked it since ages.schodt wrote:Also, ORBX import isn't working here eitherI've attached the ORBX file I'm trying to open, to this post..
I'm just trying to get the materials
I actually tried saving the materials via. Standalone first by saving it in the localDB(which didn't work), so I tried importing the ORBX file, but it isn't working either.
EDIT: OK I finally got it to work by grouping the material along with its nodes in Octane Standalone, right-clicking and saving the material it self as an ORBX file. Saving it to the localDB still makes C4D crash.
do this way. Select material and save as orbx. Then import and voila...schodt wrote:I'm just trying to get the materialsI actually tried saving the materials via. Standalone first by saving it in the localDB(which didn't work), so I tried importing the ORBX file, but it isn't working either.
