Version 2.16.2
schodt
OK so I just tried to save out some materials from standalone (v 2.15) again, and save them in the localDB. This results in that c4d closes whenever I click on the "localdb" tab in the liveDB window. I've attached the livedb folder from my prefs folder here.
liveDB.zip
(453.92 KiB) Downloaded 307 times
Workstation: Watercooled 4x GTX 780, 1500W Corsair AX1500i PSU, 4930K, 32 GB RAM, SSD and Cinema4D.
Render slave: 4X GTX 780 Asus Strix 6GB, 1200W Corsair AX1200i PSU
albehany
hi aoktar thank you for the hard work
i just install the new 2.16 and when i try make new material i get this message
schodt wrote:OK so I just tried to save out some materials from standalone (v 2.15) again, and save them in the localDB. This results in that c4d closes whenever I click on the "localdb" tab in the liveDB window. I've attached the livedb folder from my prefs folder here.
try with 2.16.
albehany wrote:hi aoktar thank you for the hard work
Thanks. Can you see any files in "res" folder in c4doctane? It says that cannot open or found *.res files
schodt
try with 2.16.
Just installed 2.16, erased liveDB folder, saved the materials via. octane standalone 2.16 - still having the same problem.
schodt wrote:
try with 2.16.
I cannot reproduce the problem here. Anyone has similar problem? Also i'm uploading a new version with some minor fixes on "localdb". May helps to you.
schodt
Also, ORBX import isn't working here either :shock: I've attached the ORBX file I'm trying to open, to this post..
Is_216.orbx
(12.54 MiB) Downloaded 328 times
schodt wrote:Also, ORBX import isn't working here either :shock: I've attached the ORBX file I'm trying to open, to this post..
what are you trying? Getting the geometry? It's not possible. Only material import should work but i haven't checked it since ages.
schodt
I'm just trying to get the materials :) I actually tried saving the materials via. Standalone first by saving it in the localDB(which didn't work), so I tried importing the ORBX file, but it isn't working either.
EDIT: OK I finally got it to work by grouping the material along with its nodes in Octane Standalone, right-clicking and saving the material it self as an ORBX file. Saving it to the localDB still makes C4D crash.
schodt wrote:I'm just trying to get the materials :) I actually tried saving the materials via. Standalone first by saving it in the localDB(which didn't work), so I tried importing the ORBX file, but it isn't working either.
do this way. Select material and save as orbx. Then import and voila...
Return to “Releases”
