GTX 980 and Yosemite
martincarlson
Updated Yosemite and Nvidia installed new web driver.
See attached.
Martin Carlson, Visual and Audial Designer at Katzenwaffe Creative Studio | www.katzenwaffe.se | Soundcloud | Twitter
Intel Core i7-5930K / ASUS X99-E WS / 2 x EVGA GeForce GTX TITAN X 12GB / 32 GB RAM / Windows 10 / C4D R16 / Octane Standalone 3.03.3 / OctaneC4D 3.03.3-R1
abstrax
It all looks correct and it should work. I can think of only two reasons why it doesn't work: Either there are still issues with the drivers or the kernels which were compiled on OSX are broken for Maxwell. Unfortunately we can't test the 980 on a Mac here. Could you check if other CUDA applications work on your system with the 980?
martincarlson
Damn! I can't get it to work. Spent hours reading forums on nvidia drivers and versions and terminal hacks. No cuda apps are working for me. I'm giving up. Will keep running windows until yosemite and nvidia are friends.
Thanks anyway!
kibbycabbit
Please try installing CUDA 6.5.25
This is a working version.. The new 6.5.33 doesn't work.
Let me know if it doesn't work. I'll head home and find out what Nvidia driver I use then you can use the combo (Nvidia and CUDA) to get it to work. :)
System #1: Mac Pro Early 2009, 12GB ECC RAM, Display: GTX 750 Ti 2GB (Maxwell) + CUDA: GTX 980 4GB (Maxwell)
System #2: MacBook Pro /w Retina 15", 16GB RAM, GT 650M 1GB
System #3: PC Windows i9 6 cores, 16GB RAM, RTX 2080 SUPER 8GB
kibbycabbit
Ok, known working setup:
GPU: 343.02.01f01
CUDA: 6.5.25
OS: Yosemite 10.10.1
martincarlson
kibbycabbit wrote:Ok, known working setup:
GPU: 343.02.01f01
CUDA: 6.5.25
Thanks for that info! Will try this. To downgrade CUDA - is it just to download apropriate installer and it will overwrite?
kibbycabbit
Yep. Install will overwrite installed copy.
kibbycabbit
Does it work?
martincarlson
Haven't had the chance to try it yet. In the middle of a project right now so better finish that first.
3dworks
for mac there are different CUDA installers for maxwell 2 type (geforce 980 and 970) and all older cards, probably you did install the wrong one? this seems to be the latest one for 980 cards:
http://www.nvidia.com/object/macosx-cud ... river.html
see discussion and tips here:
http://www.xlr8yourmac.com/index.html#N ... DA_Updates
ordered a 980 card myself, so i will check this next week.
cheers
markus
Specs: Apple MacBook Pro M1 max 64GB 2TB, MacOS 12.5 / MacPro 5,1 with NVIDIA GeForce GTX 1080 8G, MacOS 10.13.6 / Mac Pro 5,1 with AMD RX5700 8G, MacOS 12.3.1 / HP Z600 with NVIDIA 3060 RTX 12G, Windows 10 pro + Netstor GPU box, 4 x NVIDIA GTX 980ti 6G.
Return to “Plugin Discussion/Support”
