Version 2.14.0 - TEST
garytyler
A "Reset to Defaults" option on each setting should definitely happen. I don't understand what there is to agree on? This is generally an expected feature in any professional software.
Win 8.1 / C4D R16 / Maya '16 / 5x GTX 980 Ti
Hi garytyler,
Ok understand. Please don't compare with others. Because Live viewer is not working on render data. I don't store live viewer's settings in vpost settings. It holds in a special object of current scene's else vpost section. That's the reason of this confusion. Should be a mistake on somewhere, i'll fix it.
garytyler wrote:A "Reset to Defaults" option on each setting should definitely happen. I don't understand what there is to agree on? This is generally an expected feature in any professional software.
problem is for custom sliders. I cannot add this option with custom sliders. I'll add a option to allow the c4d's sliders.
garytyler
Sorry for comparing. For the record, I own and use Octane C4D Plugin because it is the best. I am giving feedback because I know you are listening and it shows in every release. It's hands down the best best C4D renderer.
Thanks again!
garytyler wrote:Sorry for comparing. For the record, I own and use Octane C4D Plugin because it is the best. I am giving feedback because I know you are listening and it shows in every release. It's hands down the best best C4D renderer.
Thanks again!
thanks for report. Definitely i'll try to fix.
augdalmo
Hi Aoktar
I have observed that Pick Focus and Pick material doesn't work in LV if you have selected Render region before. It doesn't matter where you click, inside or outside of Region.
Instead on Standalone you can pick focus, object and material also if Render Region is active. If you pick focus at any point in the image, obviously will be update only in Region.
Do you think it will possible in future solve this problem?
Thanks for attention
augdalmo wrote:Hi Aoktar
yes correct! Region mode disables thus. I'll look for a solution.
turtles123
hi! i don't know if this is a problem related to this version, but i noticed this...
every time i set my material this way
the float texture nodes seems to be stuck together i can't move them indipendently. even if i cange one of them or both to rgb spectrum i have all kinds of problems... i change one value and the other becomes black with no reason. is this a bug or i am setting materials the wrong way?
(this setting is the same i saw from silverwing vfx obstacle scene http://www.silverwing-vfx.de/free_stuff.html)
turtles123 wrote:hi! i don't know if this is a problem related to this version, but i noticed this...
yes, i'm aware of. This is a problem of custom sliders. I think that's the time of replacement the sliders with default sliders. At least will be a option to choose
efex
I used to render different Octane scenes with the Render Manager and now Cinema crashes each time when the render wants to start with the next scene.
PC Win7x64 / 64gb / psu 1200 / [email protected] / octane for c4d 2.14.0 / R15 & R16 / 2xTitan Black + 1xTitan Black / nvidia 344.65
