OctaneRender™ Standalone 2.14
thefishnut
Unfortunately I've another crash today :(
Likewise, this is a reoccurring crash that has caused me to loose a lot of work many times. :x
As far as I can tell it occurs when clicking in repetition on areas around the node view port and render screen, while rendering. This has happened many times, and in two different ways, sometimes octane simply crashes with a warning box saying the program has stopped working. Other times it appears with a red error box indicating the path of the 2.14 octane .exe and that it has crashed.
Unfortunately this is a hard to describe and hard to reproduce error, but it is occurring within all the betas constantly, forcing me to work with the 2.06 version.
Win 8 64 | 2 x Geforce GTX780 6gb | i7 4790k | 32GB
Dmi3ryd
thefishnut it is very intresting version.
First I think that I've problem with my video card (Asus 780 TI Docu2). But I remember that this broblem didn't appear in earlier versions of octander render.
Second may be file have broken geometry. But in this situation modo - octane plugin working very well.
I can share personal project but I didn't think that problem at current actane file.
P.S.
Dear developers, what do you think?
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
thefishnut
Occurred again, this time there was not an excessive amount of mouse clicks, so my previous post may be incorrect. I simple clicked between the multiply texture and the mix texture, right on the connecting cord, once, and I received this error. This has occurred many times now.
grimm
Up, up out of the murky depths the old bug has resurfaced again. On Linux if I select the maximise pane button for the render viewport it locks Octane up and I have to kill it. I tested it on several ocs files and they all lock up. Even if you don't load a file and just have started Octane fresh.
ff7darkcloud
I think you clicked and disconnected the node while it was rendering? That causes me crashes too.
( PC ) Win10 x64 | 2xRTX2080TI | ASUS Rampage VI Extreme | i9-7900x | 32GB | 1600W
( Laptop ) Win10 x64 | RTX2080Max-Q | Lenovo Legion Y740 | i7-9750H | 32GB - Octane Standalone Win 10/ Sketchup 2019
PORTFOLIO: https://renderspace.wixsite.com/portfolio
manalokos
On the "render imported animation" script "skip existing image file" option doesn't work.
aLeXXtoR
manalokos wrote:On the "render imported animation" script "skip existing image file" option doesn't work.
There's more! :) And there's a fix already posted.
Win 10 Pro 64bit | GeForce RTX 2070 SUPER 8Gb | AMD Ryzen 7 3700X | 32GB RAM
WebSite
Showreel
stratified
grimm wrote:Up, up out of the murky depths the old bug has resurfaced again. On Linux if I select the maximise pane button for the render viewport it locks Octane up and I have to kill it. I tested it on several ocs files and they all lock up. Even if you don't load a file and just have started Octane fresh.
Yes, I can confirm this on Linux. It does seem that it only happens with the OpenGL viewport. You can work around it by choosing the software viewport in the application preferences. We will look into this.
cheers,
Thomas
grimm
Thanks Thomas,
I keep forgetting about that option, as I never change it. :)
Jason
stratified
thefishnut wrote:Occurred again, this time there was not an excessive amount of mouse clicks, so my previous post may be incorrect. I simple clicked between the multiply texture and the mix texture, right on the connecting cord, once, and I received this error. This has occurred many times now.
ff7darkcloud wrote:I think you clicked and disconnected the node while it was rendering? That causes me crashes too.
Thanks for the bug reports. The crash will be fixed in the 2.15 release.
cheers,
Thomas
