lights dont seem to work
ArcaneParadigm
with area light at 3206.867 power barely doing anything
I add just a octane area light and it does nothing
add a daylight obj and turn power down - area light works in simple scene
In this scene it only vaguely works no matter how much i turn up power or make the area light big it only affects the specular everything else stays black / power of 3200 on the area light thats ridiculous and its not really doing anything
when I turn up daylight everything brightens
what am i doing wrong ?
Also changing the time on the sun doesnt really seem to logically effect where the sun is or add shadows - do I have to add shadows turned on in light or does Octane suppose to add shadows on all lights no matter what ??
changed daylight to power of 5
ArcaneParadigm
the only way i can get anything is
turn blackbody to texture
and turn power up to 10,000 - the image should be completly white blasted out
ArcaneParadigm
that yellow square on first picture is the arealight - its huge and the power is over 3000
FooZe
Check the back side of the plane, is it emitting out of there? (ie: plane is facing the wrong way).
It also might be a scale problem (large scales require large power values)
ArcaneParadigm
I've tried to rotate plane its got the blue arrow in direction of stuff
I scaled it from what it was to massive no difference
ArcaneParadigm
all the objects even have object tags
FooZe
Does increasing the power on the planes emitter to max (1,000,000), and setting the efficiency_or_texture to white make any difference?
ArcaneParadigm
they are already white
if i set to black all light goes away
FooZe
What kernel are you using and what are the depth's set in the kernel?
ArcaneParadigm
I tried to attach zip to th elast post but doesnt seem to work
tried direct light and pathtracing
depth of 16 on diff and spec everything pretty much default doesnt matter what kernel
can i send u a file to look at or is the zip working I tried ot attach ?
crystalworld3Octane 2.zip
(1.39 MiB) Downloaded 159 times
