OctaneRender for Carrara 2.06.0051 [Test]
Carrara (Integrated Plugin developed by Sighman)
SciFiFunk
That's good to hear.
I will continue with my schedule then. As you can see as a background task I'll continue to test replication in its various forms as this is important to me, although we have the all clear as far as the film goes.
With regards Country Lane. I removed items all the way down to just 4 birch trees before it would render. So somehow it's not coping with Carraras built-in tree objects. I must confess I rarely go here but was tempted to buy those Country Lane and Stoney Creek bundles as they are on offer.
Here is the log file of the reduced scene. To be clear I am perfectly happy with the plug in from the films point of view, just want to give the animation a good testing as soon as I can. This is just shame for me as I bought the scenes to compare Octane vs Carrara on these nature scenes.
[21:06:28.021] Started logging on 14.09.14 22:06:28
[21:06:28.021]
[21:06:28.021] Flag Type Value Prefix Description
[21:06:28.021] ------------------------- ------- ---------- ---------- --------------------------------------------------------------------------------
[21:06:28.021] apiChangeMgr release 0 "apiChngMgr" Logs ApiChangeManager::update().
[21:06:28.021] apiNetwork release 0 "apiNetwork" Logs all important calls into ApiNetRenderManager
[21:06:28.021] apiNodeSystem release 0 "apiNodeSys" Logs all write operations in the API node system.
[21:06:28.021] apiProject release 0 "apiProject" Logs all important calls into ApiProjectManager.
[21:06:28.021] apiRender release 0 "apiRender" Logs all important calls into ApiRenderEngine.
[21:06:28.021] cudaProf release 0 "cudaProf" Enables general logging of CUDA profiling.
[21:06:28.021] cudaProfDetail release 0 "cudaProf" Enables logging of single CUDA activity records.
[21:06:28.021] heartbeat release 0 "network" Enables logging of the network rendering heartbeat.
[21:06:28.021] logAppendToFile release 0 "" If enabled, logging will be to the already existing log file appended
[21:06:28.021] logFlags release 1 "" If enabled, all log flags will be dumped during startup
[21:06:28.021] logForceFlush release 0 "" If enabled, every logged line will be flushed
[21:06:28.021] logJuce release 0 "JUCE" If enabled, JUCE logging will go through the logging framework of Octane
[21:06:28.021] logPrefix release 1 "" If enabled, each log line will have a prefix
[21:06:28.021] logTime release 1 "" If enabled, each log line will have a timestamp
[21:06:28.021] logToDebugConsole release 0 "" If enabled, logging will go to the debug console (Windows only)
[21:06:28.021] logToFile release 0 "" If enabled, logging will go to a log file
[21:06:28.021] logToStdout release 0 "" If enabled, logging will go to standard out
[21:06:28.021] netRender release 0 "netRender" General logging of network rendering
[21:06:28.021]
[21:06:28.021] OctaneRender version 2.06 (2060000)
[21:06:28.021]
[21:06:38.396] OctaneSceneManager::SetSceneDocument(000000002C27F9F4)
[21:06:39.035] Scene contents: 7 primitives, 2 cameras, 3 lights
[21:06:44.027] OctaneSceneManager::RenderWindowOpened()
[21:06:45.072] OctaneSceneManager::LoadScene(000000002C21CEDC)
[21:06:45.088] SetDepthOfField(dof=0.000000, autoFocus=1
[21:06:45.119] UpdateTexture - Unknown shader: Subtract ['smin']
[21:07:17.599] OctaneSceneManager::RenderWindowClosed
[21:07:17.599] OctaneSceneManager::UnloadScene(000000002C21CEDC,true)
[21:07:17.599] GeometryManager::Unload
[21:07:17.599] MaterialManager::Unload
[21:07:17.599] MaterialManager::Reset
[21:07:17.599] TextureMapCache::Reset
[21:07:17.599] RenderTargetManager::Reset
[21:07:17.599] GeometryManager::Reset
[21:07:17.599] ObjectManager::Reset
[21:07:17.599] OctaneGeometry Count = 0
[21:07:17.599] OctaneMasterShader Count = 0
[21:07:17.599] OctaneMasterObject Count = 0
[21:07:17.599] OctaneMaterialMap Count = 0
[21:09:51.119] OctaneSceneManager::RenderWindowOpened()
[21:09:52.133] OctaneSceneManager::LoadScene(000000002C21CEDC)
[21:09:52.164] UpdateTexture - Unknown shader: Subtract ['smin']
Sighman
SciFiFunk wrote: HF Country Lane. open OVP get an error "The scene is too complex and could not be loaded into Octane. Please reduce the complexity of the scene and try again". Carrara is up to 5GB memory (I have an 8GB machine) so fits ok (80% space usage) - although the whole thing is sluggish. It will render in Carrara native, the ovp reads 52/2536/3221 as memory usage.
Please let me know if I can supply any more useful info to solve this.
Steve
I've tried that scene in both 8.1 and 8.5 without a problem on both my Titan and 580. Peek system memory used was around 5.3GB. The scene easily fits into Octane so I don't know why you are getting the 'complex' message which means that the Octane API failed to load the scene. I don't see any errors in the log
Edit: My graphic driver version is 340.52.
HF Country Lane in Carrara 8.1
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
SciFiFunk
The only thread I've got to go on is that the scene works when I remove most of the scene. (i.e. left with 4 birch trees).
It's late here, so I have to stop for now. I tried some built in carrara landscape scenes no problem, tried replicating a tree a thousand times, no problem.
I guess in my spare time I can keep trying reduced versions of the Howie scenes. I'm not sure how to further the investigation of this, unless anyone else has wisdom to add.
EDIT do I need to add some more memory (only on 8GB), or increase some workspace somewhere to allow it space to buffer some calculations?
Sighman
SciFiFunk wrote:The only thread I've got to go on is that the scene works when I remove most of the scene. (i.e. left with 4 birch trees).
I've sent you a PM.
8GB is a bit tight. It depends on what else you are running. What is your graphics card and NVIDIA driver version?
SciFiFunk
Thanks.
I am running with 2 graphics cards GTX780Ti (3GB) and GTX760 (4GB) so 3GB scenes max. NVIDIA version 335.23
I see 340.52 is available, I'm loathed to upset the system unless this is an essential upgrade.
Sighman
SciFiFunk wrote:Thanks.
Hmm, 335.23 is the required version according to the Octane minimum requirements. It is crashing in the Octane API so I don't know what else to suggest. I am running 340.52.
EDIT: I just booted to an older partition which has NVIDIA version 337.88. I did a fresh install of Carrara 8.1 plus OR4C 51. No problem loading the scene. Hopefully the exception report will give more details...
Tugpsx
I have cleared Carrara's cache folder. The system has 16GB RAM a GTX-480 1.5GB and a GTX660Ti 3.0GB this is what happens when I load Howie's scenes into Octane.
The System sits on the loading or compiling screen then it eventually crashes Carrara
Howie OC Error
Howie OC Error
Sighman
I have tried the following HF scenes and they all load without error:
Country Lane
Country Lane Autumn
Country Lane - Hedgerow
Country Lane - Hedgerow Autumn
Country Lane 2
Country Lane 2 Autumnia
Darkwald
Darkwald Cinders
Darkwald Frost
Secret Lake
Secret Lake Spring
Secret Lake Summer
Secret Lake Winter
Stoney Creek - Beech Dale Autumn
Stoney Creek - Beech Dale Spring
Stoney Creek - Spruce Vale
Stoney Creek
Japanese Tea Garden
Japanese Tea Garden Autumn
Japanese Tea Garden Spring
Harpsburg
Noble Pines
Yule Cottage
Sighman
Ok, I have reproduced the problem with loading the Country Lane scene. It is very strange. I have two installs of Carrara. A clean install with only the Octane plugin and an install with all the plugins that I own. The scene loads fine in the clean install, it will not load in the install with the additional plugins. Now I am going to have to figure out which one is causing the problem. This may take awhile.
SciFiFunk
Sighman wrote:Ok, I have reproduced the problem with loading the Country Lane scene. It is very strange. I have two installs of Carrara. A clean install with only the Octane plugin and an install with all the plugins that I own. The scene loads fine in the clean install, it will not load in the install with the additional plugins. Now I am going to have to figure out which one is causing the problem. This may take awhile.
Well done. It's progress with something firm to go on. I'm going back to the modelling then..
Return to “Carrara”
