Victoria 6 - Octane Standalone
DOrdiales
Hello,
I uploaded a material in Live DB: Materials: Organic: Skin: "D.Ordiales - Skin V6".
Do You know how to put it a picture? I've uploaded 2 times by mistake, I deleted one of them, but still appears.
To use the material:
1. Attach the corresponding surfaces.
2. Attach the corresponding maps.
For example, We can connect the surfaces nostrils, lips and face with the material, and associated the corresponding textures:
I hope that helps.
greetings
FooZe
DOrdiales wrote:Hello,
I have removed the material from the DB, previews are generated by us periodically.
Chris.
DOrdiales
Chris.
Thanks a lot, Chris.
xxdanbrowne
Comparison (left to right of some of the shaders)
Diffuse, Kayze's, Cordiales V6, Tonysculptor r20
(fairly sure I screwed something up with the scattering scale with Tony's and I don't know what went wrong with Kayze's)
richertmx
I cannot find the Skin in the LiveDB, anyone else experience this problem?
Anyway, thanks for sharing your method/material =)
Gigabyte GA-X99-UD4 | Intel Core I7 5820K | Crucial DDR4 16 GB | 2x MSI Gefore GTX 780ti 1x Geforce GTX 780 | Seasonic Platinum Series 1000W
leo64
Could someone please share the macro D.Ordiales - skin V6?
DOrdiales
leo64 wrote:Could someone please share the macro D.Ordiales - skin V6?
Stevenyang0430
I came back and checked again , and found the new images you've created.
All I want to say is ... WOW
Especially for the second last one, the lighting is just so real!
How many lights did you put in that scene? (The one in night time)
TRRazor
If you guy fancy a decent SSS skin shader for OctaneRender you should definitely check out our RedSpec TGX for DAZ Studio shader.
We'll release this probably as soon as the next week, and it will not only deliver stunning texture detail on your characters, but also phsically calculated sub-surface-scattering effects.
Not only is it a single shader fo everything, but we went to great lengths and developed materials for every single limb of Victoria 4 / and 6.
You can check out our deviantart group here: http://redspecsss.deviantart.com/
And our official homepage where you can already purchase the Poser / OctaneRender shaders.
If you've got any questions about our work - don't hesitate to ask :)
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
DOrdiales
Stevenyang0430 wrote:I came back and checked again , and found the new images you've created.
Thank you Steven.
For day scene, I used Octane's "Daylight":
For the night scene I have used several lights:
A lamp (temperature: 3000 - power: 30,000):
A light on the shelf (temperature: 2000 - power: 250):
A hose (temperature: 4000 - power: 6,000):
A light on the ground (temperature: 2500 - power: 5,000):
A ceiling light (temperature: 3000 - power: 100,000). I have created a false ceiling to play with opacity:
I have used a little light "Texture Environment":
And I used the kernel Path Tracing:
Finally, I have set some parameters in "Imager" section.
Greetings
Return to “Works In Progress”
