Hello there,
I'm trying to render this spline animation and everything looks great on live viewer but when I try to do the final render I don't get the same shading resoult.
Scene file attached.
What am I doing wrong?
Thank you for your help.
Marco
Picture Viewer doesn't match Live Viewer
- pvtolv_problem.zip
- (131.84 KiB) Downloaded 282 times
When you are enabled multipass, C4D changes color profile of output. So you should use floatbuffer(tonemapped) in Octane Render settings
you should see correct colors when you open the saved images in after effects, etc.
problem could be related with 2.02. I have tweaked colour behaviour on some recent version. 2.05 is best. I remember that we tested colors for every workflow. it should works as I mentioned. I'm away from pc to test it
strange_attractor_tracer.abc file is missing
if you could re-upload
attached your revised scene with some hairs. It looks same here. Only different is hair that has not same geometry in LV against PV
- pvtolv_problem2.zip
- (713.37 KiB) Downloaded 288 times
Sorry Aoktar, there must have been a misunderstanding.
Here is a scene file with the alembic file included.
My problem is that the splines in the live viewer seems to be effected by the noise in the shader but when i do the render in picture viewer the splines looks flat with one color.
Hope is clear.
Thanks.
Hope is clear.
Thanks.
- (12.51 MiB) Downloaded 342 times
