Picture Viewer doesn't match Live Viewer
mrbrown
Hello there,
I'm trying to render this spline animation and everything looks great on live viewer but when I try to do the final render I don't get the same shading resoult.
Scene file attached.
What am I doing wrong?
Thank you for your help.
Marco
pvtolv_problem.zip
(131.84 KiB) Downloaded 251 times
When you are enabled multipass, C4D changes color profile of output. So you should use floatbuffer(tonemapped) in Octane Render settings
mrbrown
Hi Aoktar, thank you for your fast answer.
like this? It doesn't look like it helps..
you should see correct colors when you open the saved images in after effects, etc.
mrbrown
Unfortunately I don't, Photoshop and AE open the saved imaged just like i see it in the picture viewer.
Anything else you can think of?
Thank you again for your time and help.
Marco
problem could be related with 2.02. I have tweaked colour behaviour on some recent version. 2.05 is best. I remember that we tested colors for every workflow. it should works as I mentioned. I'm away from pc to test it
mrbrown
Updated to latest standalone and c4d plugin.
Problem still there.
Please let me know when you get a chance to look at the file.
enigmasi
strange_attractor_tracer.abc file is missing
if you could re-upload
attached your revised scene with some hairs. It looks same here. Only different is hair that has not same geometry in LV against PV
pvtolv_problem2.zip
(713.37 KiB) Downloaded 262 times
mrbrown
Sorry Aoktar, there must have been a misunderstanding.
Here is a scene file with the alembic file included.
My problem is that the splines in the live viewer seems to be effected by the noise in the shader but when i do the render in picture viewer the splines looks flat with one color.
Hope is clear.
Thanks.
pvtolv_problem2.zip
(12.51 MiB) Downloaded 282 times
