Hi all,
i'm working some fixes with new sdk(2.05). I'm thinking to release when i feel it's ready to publish. Targetted some reports which has been done in this thread.
Some of these are; freezeing problems on materials which has C4D shaders. Some minor workflow tweaks for better handling the scenes and more....
And 2.05.2 has different exposure behaviour over older versions. Details are in thread:
http://render.otoy.com/forum/viewtopic.php?f=24&t=41404
Version 2.05.0 - Updated on (14.08.14)
Hi Aoktar,
I've a curious bug since the last version 2.04.1: settings aren't kept after each restart of C4D but seems to be ok. By sample my account is ok and activated but nothing appears in the tab. It's the first time i've this kind of bug since a very long time (probably before V1).
My version of Cinema 4D is 14.042.
Any idea to restore and keep my settings?
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
Hi Aoktar,
Another subject about the localDB in the standalone and the DB access of the plugin. I've tried to define the LocalDB of the standalone to the same folder as the USER folder of the DB access of the plugin (something like ...\AppData\Roaming\MAXON\CINEMA 4D R14_xxxxxxx\prefs\liveDB\USER). Globaly it works fine and i'm able to open materials created inside C4D in the standalone and open materials created inside the standalone in C4D.
I think it could be a very interesting workflow but i've two little problems in the standalone: every materials from C4D comes with the name "root" in the standalone and the standalone says there is no previewable node in the package. Do you think there is some solution(s) for these problems
I get the same thing. Also my list of GPU's are all unchecked, yet everything works normally.atome451 wrote:Hi Aoktar,
alec
Alec Syme
http://www.fuseanimation.com
-Gigabyte X79-UP4 - Intel i7 3930 3.4 - Windows 8.1 Pro 64bit - EVGA TITAN X7 - 32 Gigs Corsair 1600 4 channel RAM -
If you click the settings button, the proper settings window will pop up. It doesn't refresh when you switch projects anymore.
1 Dell Z840 with 2x Titan XP's
2 Digital Storm Hailstorm/Win8/32GB/EVGA Titan x4
2 Server blades with 4 Tesla K80's
gpus are unchecked when stop the render. But you should see checked when open settings window. This is result of less power consumptionASyme1 wrote:I get the same thing. Also my list of GPU's are all unchecked, yet everything works normally.atome451 wrote:Hi Aoktar,
alec
aoktar wrote:gpus are unchecked when stop the render. But you should see checked when open settings window. This is result of less power consumptionASyme1 wrote:I get the same thing. Also my list of GPU's are all unchecked, yet everything works normally.atome451 wrote:Hi Aoktar,
alec
Well, that's not what I'm seeing. It seems to be working fine with nothing checked.
alec
Alec Syme
ok, problems is caused by saved window. You should see correct selection, when you close/open.ASyme1 wrote:
alec
I have found just hitting the settings button will update the settings to make them correct. Unless i'm misunderstanding the issue
