Version 2.05.0 - Updated on (14.08.14)
Hi all,
This is new build which is based on Octane 2.05. Please keep updated Standalone version to plugin for Network Rendering
Changes for 2.05.0
- Same changes of Standalone 2.05. Please read for critical change on exposure behaviour: Exposure is now independent of the gamma. I.e. changing gamma does not change the whitepoint anymore.
calculation for new exposure for old scenes:
newExposure = oldExposure * pow(118./255., gamma - 1.);
More details in Standalone 2.05 topic: http://render.otoy.com/forum/viewtopic.php?f=24&t=41404
Others changes:
- saving user materials to livedb to can be recognised by Standalone
- Fixed settings issue on saved settings dialog.
- Wrong LV size issue after doing render to picture viewer.
- Also some other minor bug fixes/improvements on c4d shaders, missing images, workflow handling, material previews, etc....
Changes for 2.04.1
- Some fixes for bug reports, mostly for opengl previews of mixmaterial and multicpu rendering on C4D shaders
Changes for 2.04
- SDK 2.04 features: http://render.otoy.com/forum/viewtopic.php?f=24&t=41308
- Fixes/improvements on render region tool
- Info channel fixes/improvements
- Fixes on displacement
- Fixes for texture problem on Team Render
changes for 2.03
- Fixed displacement and mblur problems(by Sdk/plugin)
- Faster and higher quality convertion on native C4D shaders(multicore cpu not stabile, Windows only), new C4D shader settings.
- render instance will update anymore only with objecttag, better viewport performance.
- sticky render info
- Low gpu usage when Octane windows are closed or scene resetted
- speed optimisation for workflow
- Octane gradient fix
- Object linking in Projection node, it's accounting the scale of objects now
New for C4D shader rendering with multi core for cpus (multi core is not stable)
improved displacement with c4d shaders
changes since over 2.00:
- SDK 2.02 fixes
- render instances will update if has objecttag(meshno>0)
- render region is working on anition renderings(in picture viewer)
- render region will affect(picture viewer renderings)
- little fix on update detection for (visibility changes on Live Viewer). It should work better now
- fix for wrong multipass colors, it should give correct values as well on some compositing softwares.
- displacement node uses own resolution for native c4d shaders
- New render setting parameters. Network rendering, clay mode, render region
Windows version (R12-R15)
2.05.0: http://render.otoy.com/customerdownload ... .0-win.zip (LATEST)
2.04.1: http://render.otoy.com/customerdownload ... .1-win.zip
2.02: http://render.otoy.com/customerdownload ... 02-win.zip
2.01: http://render.otoy.com/customerdownload ... 01-win.zip
Also previous version can be downloaded in Downloads section from your accounts.
MacosX version (R13-R15)
2.05.0 : http://render.otoy.com/customerdownload ... Macosx.zip (LATEST)
2.04.1 : http://render.otoy.com/customerdownload ... Macosx.zip
2.02 : http://render.otoy.com/customerdownload ... Macosx.zip
2.01 : http://render.otoy.com/customerdownload ... Macosx.zip
Demo version is available in downloads section of web site
this version has some fix and improvements about mostly in motion blur.
Objecttag now has a better switch for changing object motion blur effect.
Several problems has fixed on render instances and timesampling.
Last, there is some minor tweaks in several functions.
IMPORTANT INSTALL NOTE:
This version requires Nvidia driver 335.xx or newer. Also matching version of Standalone 2.0 is highly recommended.
And remove all old plugin files before installing. Any version conflict or old drivers can cause crashes
Cuda driver for Macos: http://www.nvidia.com/object/macosx-cud ... river.html
NET RENDER document: http://render.otoy.com/manuals/Standalo ... ge_id=1248
Supported features:
Displacement(activate with displacement checkbox in properties)
Hair rendering
Full motion blur for geometry and camera
Rounded edges
Opensubdiv
Render regions
Distributed rendering
Daylight+texture environment
Random color texture for instances
Demo scenes for 2.00
http://render.otoy.com/customerdownload ... amples.zip
Demo scenes for 1.50
Facebook page:
https://www.facebook.com/octaneforcinema4d
Bug reports:
I'll be happy, if anyone can be spesific with bug reports.
I need to know that plugin version/Os/HW, bugreport zip. Last operations before crashes.
Thanks for contributions
Best regards,
Ahmet Oktar
displacement.rar
new motionblur control
(238.85 KiB) Downloaded 656 times
ten
Very cool, thanks Ahmet. Gonna test a bit now ! :D
edit: Note to others trying this who might be as stupid as me :) , remember to upgrade the C4D plugin in your account as well as the standalone license or it wont run. The plug upgrade is free for a limited time.
ten
( PC ) i7 5960x octal 4.5ghz / 64GB / 2x Titan X 12GB / 1x 780 6GB - ( Laptop ) i7 4790k 4ghz / 32GB / 980M 8GB - Octane CD4 2.x / C4DR16.x / win 8.x
ten
played with some of the demo scenes... all very nice! mblur and hair is fantastic.... will play some more later but great so far!
ten
R_Flash
How upgrade and activate installed 1.xx plugin to 2.00? I download and install 2.00, but after loading C4D reports "...wrong UserID\password combination..." Where get right ID and password? Standalone version installed and working well. Thx
Win7, i7 950, 12Gb RAM, GTX580
jagger
same here
intel i7 3770k // 2 x Evga Titan Superclocked 6gb Vram // 16gb RAM
http://www.octavioalonso.com
eyeonestudio
Already Upgrade. But My C4D Octane Account Still 1.x :o
R_Flash
Eyeonestudio how did you upgrade plugin?
decade
It doesn't just appear in the account. You have to go back to the upgrade page with the blue truck on (at the 'home' of the site)and click upgrade again. Then, it pops up just the plugin upgrade, for 39.95. But when you actually go to buy it, it's free.
Now your cinema plugin license is upgraded to 2.0 & you don't have to do anything more.
jagger
in the displacement example nothing happens...
how to use the displacement?
UglyStupidHonest
displacement is not working yet it seems!
