Hi there,
Just bought the 2.0 version.
Every time I try making a render of particles using the particle engine option, c4d crashes.
There is no sphere "with render perfect", just a plane and a basic X-Particles setup.
Seems like a basic c4d emitter is working without crashing.
Particle engine crash
hi,
can you post bugreport.zip? some info, renderperfect causes no polygon. also check octane sample scenes. it has some examples for particles. you have some options; best is to use render instances in particles. also particle engine is a experimental option.
Here is the Bugreport.zip
I put very low sample and very few particles.
- _BugReport.zip
- (28.87 KiB) Downloaded 190 times
FlyStudio
Win7 64 | Geforce GTX760 | i7 3930K | 32GB
Hi,Fly wrote:Good morning !
Did you find anything usefull about X-particles and the "particle engine" option ?
Thanks for your help.
not really. It's working well here. Can you post your scene?
Here it is.
The problem is maybe coming from the X-Particle version I have...
Thanks !
Thanks !
- Particles_test.zip
- (50.26 KiB) Downloaded 198 times
FlyStudio
Hello,
I was sure that x-particle does not work with octane but no I see that I was wrong
I had old version of x particle and it was crashing, but with last version works nice.
Please help me how to add octane material on X-particle if anyone know.
Thanks in advance
Alex
Thanks in advance
Alex
Product Designer & 3D Generalist
Windows 8.1 | 2X GTX Titan Black | 8 X GTX 980 | Intel Xeon | EVGA Classified SR-2 | 48 GB ECC RAM | 256 GTX Neutron SSD | X-Particle Pro 2.5 | Octane 2.16
just put a octane material to emitter. Also may be a sample in demo scenes. Compatibility will be extended for shapes when i found some times
