some more procedural metals - got a good rust there
acc24ex
I got me some nice rust via gradient etc..
- materials mostly procedurals, attacted is the material library but for 3dsmax 2015 - usually doesn't work in lower version..
- now where is that implementation to upload to octane library - I could export this, but I don't want to be bothered with it
check this one
added the orbx file - the metal effect is dependable on object size, so if it is too small it will look wrong.. anyway
material sphere metal orbx.zip
(3.73 MiB) Downloaded 752 times
metal 3dsmax 2015 materila lib.zip
(20.1 KiB) Downloaded 446 times
Jorgensen
hi acc24ex
great texture works - especalliy the 'ball' - wow.
just a dumb question - could this be done in Sketchup?
acc24ex
which part - material or ball? - not sure about the ball there are some plugins that simulate some subdiv techniques
- also check out the original post i added the orbX file in .zip so you can check it out in octane
- the material looks worse on the octane material ball than mine - I am guessing because of the size of the material - also we obviously need a bit different material ball to test theese kinds of materials
- just discovered I accidentally made a bullet hole - so I guess this is how you could make quick bullet holes
Jorgensen
It was the material it self I thought about.
Thanks - I will have a look at it :-)
Jorgensen
acc24ex
I tried to add to metal to LiveDB, try and find under Non organic - Metal - Scratched edges metal red - I adjusted so octanes material ball looks better - but this thing is totally dependable on object size - try and test if it works.. I might start uploading some more materials
xxdanbrowne
I made a laundry basket with your material. I think the scratched edges effect is awesome. Thanks.
I'd love to see what else you have. Procedurals are awesome.
Phantom107
Thanks for sharing this, I want to get more into procedurals and this is very helpful. I learned something!
acc24ex
- thanks for the feedback - I barely scratched the surface :)
- if this one worked OK - I'll probably try and upload more on the liveDB .. when I'm zoned in - like the classic lampshade material with darker edges - basically dirt texture (with invert on) on emmision
perro_abombao
Awesome!!! :D :D :D :D :D
Return to “Works In Progress”
