I am having an issue with Octane's Environment. I have geometry that is not touching the floor plane, but is still revealing the HRDI environment. Does anyone know of a way to fix this? Thank you.
Environment Cuts through Geometry
yes, also pls work on real world scaling if you are not doing. This makes that everything is easier and better
- blastframe
The ray-epsilon parameter worked, thank you! I'll also give the walls & floor thickness for safe measure.abstrax wrote:To things you can do: Try reducing the ray-epsilon and give your walls and floor thickness.
Thanks for the quick response!
