Blending Dirt and ImageTexture?
- blastframe
Is there a way to multiply a Dirt Map and Image Texture? I'd like to create noise at the edges of a model. I tried using the Multiply node and it didn't work as expected. Thanks!
- gordonrobb
Best to use Mix. Use the Dirt node as the amount, and mix between your texture and whatever you want the noise to be (RGB, or Texture)
- blastframe
Great, thanks! I will try it when I get home
- blastframe
I've tried the method you described and it resulted in the following output. Is there a way to multiply the noise? It seems to be in Normal blend mode. Thank you!
- blastframe
I came up with a solution that I wanted to share.
I created a Multiply node that contained my ImageTexture and a MixTexture node. Inside of the MixTexture is:
- Amount : Dirt
- Texture1 : Noise
- Texture2 : RgbSpectrum set to white
- gordonrobb
Ok I'm confused but interested.
What is wrong with the image you show as the result? Is it that the dark parts of the noise or not darkening the original texture, but the noise image is replacing the original texture? Also, not sure I understand your solution. Can you show the node setup and the result?
Ta!
Ta!
- blastframe
Hi gordonrobb,gordonrobb wrote:Ok I'm confused but interested.
Ta!
The problem with the image I showed was that the noise was not being multiplied in its blending with the ImageTexture.
Here's my setup for Custom Dirt:
- blastframe
This is the result (there is some ambient occlusion, but the streaking in the corners is created by this custom dirt material.
- gordonrobb
Looks great, but your images make no sense to me. Doesn't C4D use Nodes? Not being familiar with it, I can't translate it, in my head, to a node tree.
- blastframe
gordonrobb wrote:Looks great, but your images make no sense to me. Doesn't C4D use Nodes? Not being familiar with it, I can't translate it, in my head, to a node tree.
