Bugs report
tegatwork
EDIT : As I'm encountering a few bugs, I decided to edit the last post in order to keep them together. Aoktar, there is no need for me to solve them now, just keep them in mind for the V2 :)
BUG 1 - Texture problem with symetrical extrude nurbs with caps
I'm facing a strange bug.
I'm working on a model with lot of "simple" symetrical extrude nurbs. Everything was ok, but right now, the caps of the new objects are plain white.
I copy-pasted the objects in a new scene, and it's ok.
It sounds like the amount of symetrical objects is limited?
thanks, seems like a bug. I'm very busy on 2.0 development. If it's a big problem, i can check it, otherwise i wish to delay little.
Best,
Ahmet
tegatwork
It was just a report : I'm doing symetries by hand. That's not a huge problem so far, keep up the good work on the v2 !
tegatwork
BUG 2 : Rendering a boolean driven by a parent constrain
This time, I'm using a boolean in order to simulate the level of a liquid in a syringue. The cube is linked to the syringue's moving piece by a "Parent Constrain tag".
In the live view, everything is ok, but the boolean isn't working in while rendering.
As soon as I desactivate the constrain, everything looks ok... but I lose my animation process.
Live view
Live view
Render
Render
what's your plugin version? try last one. I think you have a object tag on top of object group
tegatwork
I'm using the last version of the plugin. I'll have a look at the object tag, it sounds like a good clue.
Thanks !
