Hi Otoy,
plz build following things for the next update:
-Octane can hadle one texture on one Polygon. This is frustrating.If i want some Alpha-Maps on my Object, i had to mix 20 Mixmaterials...not a good solution for any workflow.
-Atmospheric and volume rendering
Here is a Link to Indigo-Render:
http://www.indigorenderer.com/content/a ... provements
My wish for the next release
- Rikk The Gaijin
Those clouds look quite nice (the shadows are crap tho)
- gordonrobb
You can mix textures and put the into inputs for one material. No need to mix materials.NVN wrote:Hi Otoy,
- Rikk The Gaijin
To be fair, the texture mix node doesn't work with ANY texture. For instance, if you want to mix two normal maps you must mix the materials instead.gordonrobb wrote:You can mix textures and put the into inputs for one material. No need to mix materials.
