This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Poser, build 1.50.0.22 (STABLE RELEASE) onwards. This version is compiled against Octane 1.50 (or above), so see the requirements for that build regarding compatibility with your video card.
Pls do not save scenes with this version that you may need to open with the 1.20 version of the plugin (ie. make a backup first), since the pz3 file WILL NOT be backwardly compatible.
This version runs on Poser9/PoserPro2012 and Poser10/PoserPro2014, on Windows XP, Vista, 7 and 8.
- Operating System (ie. Win XP, Vista, 7, 8)
- 64 bit (Msg me if you need 32 bit)
- Amount of RAM
- Nvidia driver version
- Poser version (Poser -> Help -> About Poser) - list the build number (eg. 9.0.3.23027)
- OctaneRender for Plugin version (ie. X.XXa)
- Also have ready a copy of the octaneplugin.log and cuda.log file from your Poser temp direction (Poser -> Edit -> General Preferences -> Misc tab to find the temp directory)
- config.xml, which is in C:\Users\[username]\AppData\Roaming\Poser Pro\9 for Poser 9/2012 and C:\Users\[username]\AppData\Roaming\Poser Pro\10 for Poser10/2014.
Change Log from release 1.37.0.21
- Compiled against Octane 1.50
- Added option to popup a confirmation screen when closing the Viewport
Still TODO
- Allow Pasting to disconnected nodes
- Image sequences are not currently working
- Implement subd processing for props (only implemented for figures at the moment) - will require a Poser SR patch
- Specular map image power defaults to 1 at the moment for skin materials with specular maps. Probably should be about 0.2.
- Export materials to OCM format
- Fix when camera zOrbit is non-zero, AND using large xOrbit and yOrbit values puts the Octane camera out of rotation synchronisation
If you have questions....
- Read the latest up-to-date on-line manual
- Read the PDF manual (pdf manual is installed into C:\Program Files\Smith Micro\[poser version]\Documentation)
- Read the FAQ
- Watch the Features Video
- Read the Features Blog Posting
- Watch the Introductory Tutorial
- Watch the Instancing Video
- Check the Facebook Page
- Post your question on this forum thread
Limitations
Refer to the on-line manual
Download Links
Download the plugin from the following links:
- OctaneRender for Poser 1.50.0.22 (64 bit)
- OctaneRender for Poser 1.50.0.22 (32 bit)
OctaneRender® for Poser (Windows) 1.50 [STABLE] - OBSOLETE
Thanks Paul... working well... just a few interface issues to sort from the last release, but I guess they'll come... in time.
RAM: 64GB
OCTANE PLUGIN VERSION: 2022.1..1.302 Prime
DAZ STUDIO VERSION: 4.21.0.5 Pro Edition (64 bit)
RAM: 64GB
Are you referring to the "TODO" items above, as something else? (Just want to make sure my list is complete).just a few interface issues to sort from the last release, but I guess they'll come... in time.
Of course I am... your base code works well... now make it functional... I know, I know... you're busy.
RAM: 64GB
RAM: 64GB
This version installed (as did all the others) just fine and works great! Thanks! There are some things on that todo list I anxiously await as well. Keep up the good work Paul!!
i7 6800K (6 core), 24 GB, GTX 1080 8gb, Titan X 12gb
- ArminBeier
Do I have to do something special to install it?
Do I need to delete something?
I just installed it and when I load a figure I optimized for Octane, it says:
"Octane error: Tried to access null node pin"
And the texture size is is wrong.
I hope I don't have to re-optimize all my custom characters for Octane again.
OS: Win7 x64
CPU: i7-4770 @3,40GHz
Mainboard: Z87-Deluxe
GPU: 2x GTX980 Ti Hybrid
RAM: 32GB
HD: 250GB SSD
RAM: 32GB
HD: 250GB SSD
The rest of that message directs you to check the Octane Log. What did the Octane log say?I just installed it and when I load a figure I optimized for Octane, it says:
Pls see the first post at http://render.otoy.com/forum/viewtopic.php?f=45&t=37605 for details on the scale differences between Octane 1.20 and 1.50.And the texture size is is wrong.
- ArminBeier
Tried to access null node pinface_off wrote:The rest of that message directs you to check the Octane Log. What did the Octane log say?I just installed it and when I load a figure I optimized for Octane, it says:
Node type 7 is either unknown, a linker or incompatible to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000000D7A8FD0)
- Image, Floatimage and Alphaimage "scale" pins are not compatible with Octane 1.21 so will not be loaded from existing pz3 files. If texturemaps are out of scale for a particular material, "Re-Import From Poser" that material.face_off wrote:Pls see the first post at http://render.otoy.com/forum/viewtopic.php?f=45&t=37605 for details on the scale differences between Octane 1.20 and 1.50.And the texture size is is wrong.
So I have to delete all Octane nodes in the Poser material room and convert it again? So all settings are gone.
When I click "Reconvert Materials for this Prop/Figure from Poser" the same error as mentioned above appears.
If I delete all note and reconvert it works, but now I have to make everything again
OS: Win7 x64
RAM: 32GB
HD: 250GB SSD
RAM: 32GB
HD: 250GB SSD
Latest error message... but Octane didn't crash on me.
Started logging on 05.04.14 04:53:57
OctaneRender version 1.50 (1500001)
CUDA error 700 on device 0: An exception occurred on the device while executing a kernel. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
-> Kernel execution failed (wppick)
CUDA device 0: White point picking failed
-> Failed to load symbol data to the device (kernel data)
CUDA device 0: Path tracing failed
-> Failed to copy memory to device.
CUDA device 0: Failed to load data of data texture 20 of context 0 onto device
-> Failed to deallocate device memory
-> Could not get memory info
-> Failed to launch kernel (clear)
RAM: 64GB
RAM: 64GB
Deane - that looks like a graphics card issue. Was it a particularly big or complex scene? Did you have anything else using the card? Suggest re-booting and trying again.
Hope that helps.
The version 1.5 plugin is trying to create a version 1.2 node which is no longer supported. This could either be a plugin installation issue, and a plugin code issue. Can you pls re-install the plugin via the Windows Control Panel and then reinstall the 1.5 version and try again? If you still get the error - can you pls send me a small scene which demonstrates the error and I will take a closer look.Tried to access null node pin
In the majority of cases, there is no scaling of the texture in the Poser material - so the Octane version of these will work fine. The plugin will also convert the scale (from plugin version 1.2 to 1.5) if it's not 100% in some cases. So there should only be a very small number of cases where you need to adjust the scale of the texturemap in the Octane material (when using the plugin 1.5 version on 1.2 saved scenes). Again - if you have a particular scene where the textures are incorrectly scaled, send it to me and I will investigate further.So I have to delete all Octane nodes in the Poser material room and convert it again? So all settings are gone.
Hope that helps.
