Its still not working. does the files format matter?face_off wrote:I have re-implemented animated image sequences, which you can try at http://render.otoy.com/customerdownload ... _Win64.exe. It does not restart at _0001 (ie. it does not loop back to the first image when it cannot find an image), so you will need an image for each animation frame.
Let me know how you can with this pls.
Animated Image Sequence not working in Poser
- spartan00j
- Contact:
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
When you load the image, does it give you the "Animated Image Sequence"?Its still not working. does the files format matter?
- sequence.png (4.32 KiB) Viewed 3901 times
- spartan00j
- Contact:
It looks like it's only working for figures - not for props. I will post a fix shortly.
- spartan00j
- Contact:
okayface_off wrote:It looks like it's only working for figures - not for props. I will post a fix shortly.
Win 11
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
The plugin was only animating textures of the first prop/figure in the scene. This is now fixed. Can you pls re-download from the same link as before and install/test.
- spartan00j
- Contact:
works!!! thanksface_off wrote:The plugin was only animating textures of the first prop/figure in the scene. This is now fixed. Can you pls re-download from the same link as before and install/test.
Win 11
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
- spartan00j
- Contact:
hey Paul it stopped working for some reason. when i first installed it worked but now it doesn't anymore.face_off wrote:The plugin was only animating textures of the first prop/figure in the scene. This is now fixed. Can you pls re-download from the same link as before and install/test.
my specs are: Graphics Card: Geforce Gtx 780 3GB
Driver version 335.23
RAM on pc: 12GB
Operating System: windows 7 64Bit
Poser Pro 2014
Poser version: 10.0.0.24941
Win 11
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
What does "stopped working" mean pls? Is the image showing up as "Animated Image Sequence" in the material tab?
Can you post the octaneplugin.log file resulting from rendering the animation pls?
- spartan00j
- Contact:
okay I see it only shows the animated sequence when rendering. Okay sorry about it. i didn't know.face_off wrote:What does "stopped working" mean pls? Is the image showing up as "Animated Image Sequence" in the material tab?
Win 11
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
