Animated Image Sequence not working in Poser
spartan00j
face_off wrote:I have re-implemented animated image sequences, which you can try at http://render.otoy.com/customerdownload ... _Win64.exe. It does not restart at _0001 (ie. it does not loop back to the first image when it cannot find an image), so you will need an image for each animation frame.
Let me know how you can with this pls.
Its still not working. does the files format matter?
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
When you load the image, does it give you the "Animated Image Sequence"?
spartan00j
yes it looks like that.
Win 11
128GB RAM
RTX 3060 TI
It looks like it's only working for figures - not for props. I will post a fix shortly.
spartan00j
face_off wrote:It looks like it's only working for figures - not for props. I will post a fix shortly.
okay
Win 11
128GB RAM
RTX 3060 TI
The plugin was only animating textures of the first prop/figure in the scene. This is now fixed. Can you pls re-download from the same link as before and install/test.
spartan00j
face_off wrote:The plugin was only animating textures of the first prop/figure in the scene. This is now fixed. Can you pls re-download from the same link as before and install/test.
works!!! thanks
Win 11
128GB RAM
RTX 3060 TI
spartan00j
hey Paul it stopped working for some reason. when i first installed it worked but now it doesn't anymore.
my specs are: Graphics Card: Geforce Gtx 780 3GB
Driver version 335.23
RAM on pc: 12GB
Operating System: windows 7 64Bit
Poser Pro 2014
Poser version: 10.0.0.24941
Win 11
128GB RAM
RTX 3060 TI
What does "stopped working" mean pls? Is the image showing up as "Animated Image Sequence" in the material tab?
Can you post the octaneplugin.log file resulting from rendering the animation pls?
spartan00j
face_off wrote:What does "stopped working" mean pls? Is the image showing up as "Animated Image Sequence" in the material tab?
okay I see it only shows the animated sequence when rendering. Okay sorry about it. i didn't know.
Win 11
128GB RAM
RTX 3060 TI
Return to “Poser”
