Animated Image Sequence not working in Poser
spartan00j
hello i have version v1.50 and the Animated Image Sequence not working when i render out animation. the ending sequence name is right it ends in (imagename_0001.jpg - imagename_0900.jpg). Plus i tried png format as well. please help.
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
Yes - this is listed in the "TODO" section of the release notes http://render.otoy.com/forum/viewtopic.php?f=45&t=38937. Octane 1.5 does not support the method the Poser plugin was using for image sequences, so I will need to re-implement this.
Andygraph3D
please fix this, its very important as feature!
blogfather
Animation sequences works on my machine. But I have another problem with animations that I open a string in a moment. One problem I have always had whatever drivers, graphics cards and software versions!
win7, 64 gigabytes of RAM, Asus X79 motherboard render graphics card Geforce GTX690 both channels, Video Display Adapters GTX 750TI, latest drivers of all latest software from OCTANE
The last version that animation image sequences worked was 1.20.2.8.
Not sure what you mean by "that I open a string in a moment".
blogfather
Hi Paul!
You found the string allredy.
With the version of drivers - the newest - i use the sequence (pushing it one frame forward at a time) works. Only used .jpg.
Flemming
I have a potential solution for this - but need some feedback from you. This could be implemented by REMOVING the "Animated Image Sequence:" checkbox - and having ANY image with a filename ending in "_0001" considered animated, so at frame two the plugin would try to load the same filename ending in "_0002", etc. If say at frame 20 the plugin cannot find the filename ending in "_0020", it would start back at the filename ending in "_0001".
So in summary, all image files ending in "_0001" would be animated.
Would this work for you?
spartan00j
yes it would work for me. when will you release the updated plugin. thanks :D
Win 11
128GB RAM
RTX 3060 TI
I have re-implemented animated image sequences, which you can try at http://render.otoy.com/customerdownload ... _Win64.exe. It does not restart at _0001 (ie. it does not loop back to the first image when it cannot find an image), so you will need an image for each animation frame.
Let me know how you can with this pls.
spartan00j
face_off wrote:I have re-implemented animated image sequences, which you can try at http://render.otoy.com/customerdownload ... _Win64.exe. It does not restart at _0001 (ie. it does not loop back to the first image when it cannot find an image), so you will need an image for each animation frame.
wow! thanks you so much. :D
Win 11
128GB RAM
RTX 3060 TI
Return to “Poser”
