OctaneRender™ Standalone 1.31
Eznit
Obrigado!! Thanks :lol:
:D beta for plug in SketchUp (in development)
gardeler
Rikk The Gaijin wrote:This is what I export from Maya
And this is what comes in Octane (after I manually set the Alembic scale to centimeters)
Hi Rikk
With regards to the alembic node and assigning materials, it works differently than it does on a .obj. So far I have not been able to get shader inputs per shader in my maya scene to work at all (like it does with obj's... But what you can do is un-checkbox the "hide materials with same name". This will give you an input per shape object in the alembic in stead. This can be quite messy sometimes if you have a lot of objects that would use the same shader, but you can at least assign shaders to anything you want.
A heads up is that Maya2014 has export UV's off as default in the alembic exporter. But last time I tested maya's exporter with UV's on, it crashes octane when I tried to load the alembics. But that was a while back. I have not tested it with 1.31.
hope this helps.
roeland
To use the camera in an Alembic file you need to make a render target node and connect both the camera and geometry. If you click on the Alembic scene node only the geometry is rendered with the default preview camera.
And about the materials, the only Alembic files containing material assignments I have seen yet came from an Exocortex Crate plugin. Cinema4D can export face selections, which can also be read as materials in Octane.
Roeland
Rikk The Gaijin
gardeler wrote:Hi Rikk
hope this helps.
Thank you gardeler, unchecking the "Merge materials with the same name" option helped a bit, but like you said, I will have duplicated materials, but that's better than nothing, for now.
roeland wrote:To use the camera in an Alembic file you need to make a render target node and connect both the camera and geometry. If you click on the Alembic scene node only the geometry is rendered with the default preview camera.
Roeland
Thanks roeland, the user funk told me already how to setup the node, so that's solved.
The Exocortex Crate plugin costs $399, definitely too much just to have materials exported in alembic... :(
Rikk The Gaijin
Btw, in version 1.31 I DON'T HAVE ANY NODE for the materials in the alembic file.
If I uncheck "Merge materials with the same name" in the alembic option, just one node pops up, instead of a per-mesh node like in the previous version.
Roeland, why is this happening?
Version 1.29
Version 1.31
Rikk The Gaijin
I found another problem: the "Reset Camera View to default" doesn't work with alembic. If I accidentally move the camera in the scene, I cannot bring it back to the original position and the only thing I can do is to re-import the abc file... :?
roeland
Rikk The Gaijin wrote:Btw, in version 1.31 I DON'T HAVE ANY NODE for the materials in the alembic file.
That's a bug in the Alembic loader, we have fixed in the next release.
Roeland
Rikk The Gaijin
Roeland
Ok, great! ;)
Rikk The Gaijin
Yet, another problem... The Mix Texture node in the normal map slot seems to not work. :(
Can anyone confirm this?
xxdanbrowne
Roeland
I can confirm that material nodes show up in the standalone corresponding to assigned materials in maya exported as alembic in release 1.32. Thanks guys!
