Rotation of Texture Environment
gueoct
How to i rotate my Texture Environment? With the new version, the Rotataion option has gone.
The texture 2D Transformation rotates the Image about the wrong axis...
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
Jorgensen
not sure if this helps, but I have adjustet textures using 3ds max > object modifier > uvw xform
mbetke
I have this urgent (!) problem too. :(
Also used the 2D transformation but doesnt rotate anything.
PURE3D Visualisierungen
tonycho
i use hdr light studio 4 it can rotate
but if you in urgent
how about rotate your model ? :D
http://www.antoni3D.com
Win 7 64 |GTX 680 4 Gb (Display) | 3 x GTX690 4Gb | Intel i5 |Corsair 16GB
MaTtY631990
Use translation X instead to rotate environment map.
gueoct
tonycho wrote:how about rotate your model ? :D
are you joking? :-)
I even tried that but MultiScatter did not like Rotating.....
mbetke
Wonder why Karba doesnt show up here and give some support. it is important!
I reverted back to 1.20.
I know nothing about the 3ds max plugin - but for all the other plugins you set the projection to Spherical for the IBL image, then rotate via the Y axis. Not sure if that is possible on the 3ds max plugin or not.
MaTtY631990
gueoct wrote:How to i rotate my Texture Environment? With the new version, the Rotataion option has gone.
Karba
mbetke wrote:Wonder why Karba doesnt show up here and give some support. it is important!
I am sorry. Some times I don't have enough time to check all forum topics.
Return to “Autodesk 3Ds Max”
