OctaneRender® for 3ds max® v1.22a[Test]
Juanlife
today I install octane 1.22a for max 2013 64bits, and appear my account is DEACTIVATED, pluggin try to conect but show this error all the time, some days ago i trying to install 1.22 stand alone version and show the same error ( i report that here: http://render.otoy.com/forum/viewtopic. ... 87#p163787 ),both past versions works well, any ideas?? versions works well, any ideas??
Dom74
try to look at your firewall.
Win7 x64 - 3DSMAX 2019 - 32GB RAM - 1080 TI
GDRS
Activation , and live materials , are not working also.
Same with matte material (or we do something wrong here).
For matte shadows , can someone describe how is it done?
Karba
GDRS wrote:Activation , and live materials , are not working also.
Activation seems is standalone issue.
I will check live materials.
What is wrong with matte material?
Karba
draftart wrote:- after reopen file, (3ds Max 2011) all emission slots in diffuse material, became empty, and had to reload all textures again,
- all power in Black Body Emission reset to 100
- no chance to make simple UVW mapping when texture is in distribution slot (texture emission) sometimes work sometimes not
all checked few times
I will check emission issue.
distribution is used to set up directional map lighting only. Like ies.
It doesn't use any uv mapping.
bicket
oguzbir wrote:Can someone confirm if your IES lights are working or not?
I confirm IES lights are broken. :(
PortFolio
4 x TITAN - Win 7 64 - Octane Rocks
Elvissuperstar007
Life BD does not work
GDRS
Yes , activation for the standalone , i forgot to mention it
Live db is not working for sure.
Matte material , and matte shadows we cant just get them to work , is there a specific way to do this?
Instructions anywhere?
Thanks Karba , you rock.
cfrank78
Ahm........i allready wrote on 18th of december, on the first site, 6th post, that live DB is not working. No one cared :-P
Maybe you havent seen my post, possible. Hope you can fix it soon!
3 questions for future Karba:
1: Will 3ds plugin ever have offline materials, like c4d version has. (select, right click, make offline)
2: Is it possible to implement Camera Motion Blur in 3ds Plugin, like it is in c4d plugin!
3: will it be possible to connect / sync textures for diffuse/specular/bump/normal map? like ahmet showed in this video:
https://vimeo.com/82779935
He called it refshader and its a way to "sync" all textures for all channels, which is a huge timesaver!
happy new year everybody!
HHbomb
Like camera map too !!!!!
Return to “Autodesk 3Ds Max”
