OctaneRender™ Standalone 1.23
roeland
It depends on the host application. The only ABC file I have seen yet which contained material assignments was coming from 3DS Max + Exocortex Crate. Can you attach some file exported from Maya?
Roeland
p3taoctane
Roeland_Material_Test_ABC.abc
(20.59 KiB) Downloaded 212 times
Here ya go Roeland.
From Maya 2014 mate.
Enjoy what is left of boxing day
Peter
Rikk The Gaijin
I was playing with a test animated mesh, and it works, but I don't get any motion blur, is that normal? Does the motion blur works only for the camera movement?
And, how do you render out the animation?
Rikk The Gaijin
WHOA! I have a crash. :o
It happens systematically every time I try to move the animation slider.
Roeland, I cannot post here the file, so I will send it to you by a Private Message.
roeland
p3taoctane wrote:Roeland_Material_Test_ABC.abc
Here ya go Roeland.
Peter
There is unfortunately no material data in this file. Did you have different materials on the faces of the cube?
Roeland
roeland
Rikk The Gaijin wrote:WHOA! I have a crash. :o
OK, thanks. This is a bug in the geometry updates, and will be fixed for the next release.
Roeland
p3taoctane
Gidday Roeland
Yep each face had a different material on it.
It says that Maya 2014 is supposed to export materials as part of it's ABC export... I'll see what I can find out
Peter
Rikk The Gaijin
Roeland
Great! ;)
What about this
Rikk The Gaijin wrote:I was playing with a test animated mesh, and it works, but I don't get any motion blur, is that normal? Does the motion blur works only for the camera movement?
roeland
Motion blur is still limited to camera motion blur.
Roeland
haikalle
I think there is a problem importing animated alembic scenes from modo. I can't get it to work.
