OcDS FIRST RENDERS - FIRST PRIDE :) post here...
Moderator: BK
t_3
michael_g wrote:I converted the Hishy displacement maps to normals maps using Shader map pro but for some reason the normal maps kept overriding the bump maps, so I used just the bump maps.
octane currently can only uses a normal or a bump map: if both are applied, octane uses normal maps in favor of bump maps...
michael_g
Render number 2, getting the hang of it now I think. I still feel it`s a very expensive product and the fact your forced to buy the standalone octane when you don`t actually need it is beyond me.
SimonJM
You are buying a licence to use the engine, that happens to come bundled with the plug-in to ensure compatability. A a side-effect you also get the bonus of being able to use the standalone which will generally be a higher version.
michael_g
Victoria 4 with Danaes Dublin
Midnight queen hair.
2 very large mesh lights (1 low power, 1 high power)
Set up in DAZ 4.6, exported and rendered by Octane for DAZ studio. 14.5k samples in just 4.54 hours
Jimbo989
I use DAZ Studio to pose my characters, and the plugin works very well. I did this render in the standalone version. For some reason was not able to add a background image, need to try again, any tips on this? Does the size or format need to be specific? Anyway, she looks good with just the blue sky background I think!
cyprine
so much to learn !
michael_g
Bluebird 3d`s a bright loft not so bright :D
What started out as sun/sky render turned into a warm night time render instead, 5 light mesh spheres with varying wattage (3x60, 1x40 and 1x25), small amount of bloom and glare.
Set up in DAZ 4.6, exported and rendered by Octane for DAZ studio to 20.1k samples in just 12 hours.
SiliconAya
Some close ups I did when V6HD came out.
DrHemulen
That looks extremely good. Can you share something about your material settings?
GTX 780, 6 gigs of VRAM - Win 7 Home Premium 64 bits
RayTracey
SiliconAya wrote:Some close ups I did when V6HD came out.
Looks excellent. What skin shader are you using? Is it one from the Live DB?
Return to “DAZ Studio”
