Stabile version 1.01 (SDK 1.20.3) **** 17.01.14 ****
- shawnfrueh
Hey Aoktar I have a bug report based on the Mix materials. I made a sample scene as well. You can work with mix materials just fine when you create them, however I get the problem after I save and then re-open the file.
- octMixTest.zip
- (155.21 KiB) Downloaded 224 times
- _BugReport.zip
- (31.29 KiB) Downloaded 217 times
- Floating.Point
Hey there,
No matter what I try, the plugin won't load in C4Dr15 under MacOSX10.8.4
No Octane menu where it should be; Nothing in the console; Nada
Am I missing something here?
1 x 3930K | 1 x TitanX | 1 x GTX 970
weird, no problems here with 10.8.5Floating.Point wrote:Hey there,
could you work with the standalone 1.20 or 1.21?
could you try with r14 instead?
ciao beppe
- Floating.Point
Yeah, standalone is working fine. Its really weird. Ill try again tomorrow, perhaps I'm doing something stupid because I'm tired
hi, another thing you can do is to temporaly remove all the other plugins, maybe someone is blocking c4d-octane
ciao beppe
ciao beppe
Hi Aoktar,
I totally appreciate all the hard work you are doing on the plugin, I'm just wondering if the plugin will be usable on Win8.1 when 1.0 is released?
Again sorry to pester, and I only ask because it's such an awesome tool to have in CINEMA and would love to be able to use it
Is there any more information 8.1 users can provide to help you out?
cheers
brasc
cheers
brasc
Rig#1 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 7900K 4.7GHz | 64GB
Rig#2 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 3930K 4.4GHz | 32GB
Rig#3 Win 10 x64 | GTX 1070| GTX 1070| GTX 1070| i7 2600K 4.8GHz | 32GB
- shawnfrueh
Hey Aoktar, I have so funny things happening with emissions in octane. I want to make the light source invisible but still emit light but I get some crazy results when doing so. (This is using RC2 test3)
I am using a cube as my light source with beveled edges. The only thing that changes in the scene is the cube.
Emission with no transparency: Emission with transparency: Emission with Object tag and with no transparency: Emission with Object tag and transparency:
Sorry for delay for reply, but i'm working for next version. If it's not much critical, please wait until next.
Most parts of plugin is revised with this transation. And i hope that will be much better
Hi there! I've disperatly mean of import QTanimation Texture or Animation sequence in a material.. Wich the metod?
Aaaaaaaaaaaaaaaaaaaaaah!!!! ok excuse me!!! with Jpeg sequence works perfectly!!!
