Hi all,
Final version is available now. It's based on old stabile SDK 1.20.3. There is a seperate thread for new SDK for testin as you see.
This version has a few bug fix for mixmaterials, and finally a workaround for R15/Win8 startup problem. It has all features previous version. Enjoy it
INSTALLATION
Ok, for all users who has startup problem on R15
Be sure that you removed old files. Just copy new files to c4dOctane directory.
Also delete nvapi.dll from libsXXX folders if you get crash,
and try the older nvidia driver
DOWNLOAD LINKS
Full installer:
Version 1.01 for Windows (R12-R15)
http://render.otoy.com/customerdownload ... D-1.01.exe
Version 1.01 for Macosx (r13-r15)
http://render.otoy.com/customerdownload ... Macosx.zip
(please remove unrelated c4dOctane-R**.dylib file)
Demo version 1.00 for Windows (R13-R15) (DEMO)
http://render.otoy.com/customerdownload ... 0-DEMO.exe
changes since 1.0.0
-Fixed mix material preview crashes
changes since Beta 0.9.6
- Fixed crashes on mixmaterials
- Fixed R15/Win8.1 startup problems
- mixmaterial preview problems has been targetted
- dll conflicting problems has been fixed
- fixed a problem which is occured while doing incremental rendering with subframe motion blur
- New LiveDB manager with offline mode and user materials
- improved Render area on Live Viewer
- Autosave for Live Viewer
- Gamma setting for standart bitmaps
- lot of stability improvements
- improved material previews
- extended control for quick acces to kernels
[vimeo]http://www.vimeo.com/79926179[/vimeo]
[vimeo]http://www.vimeo.com/79464295[/vimeo]
[vimeo]http://www.vimeo.com/79335989[/vimeo]
INSTALL:
Remove old Octane files and use newer files. If you have startup errors, remove nvapi.dll's from plugin/libs folders
USAGE and CRASH REPORTS:
We need any feedback about possible problems.
If you get errors, please don't forget to post your info about plugin, os, system specs. And grab some screen caps, crash logs. You should activate log output option and keep open the console window for captures as in below picture. And try to reproduce same error and get a screen shot or console text output. Also attach the bugreport.zip which is generated by Cinema 4D. And write down some notes about how it happened.
bug report file is here:
c:\Users\USERNAME\AppData\Roaming\MAXON\Cinema4Dr15_XXXXXXXXXX\_bugreports\_BugReport.zip
Last note, If you get problems and cannot rid away, use your previous stabile relase until errors are fixed.
[/b]
Manual
http://render.otoy.com/manuals/Cinema4D
Rainasawrus Octane Render Pack – Materials
http://www.rainasawrus.com/products-fre ... ender-pack
(special thanks to rainasawrus)
Vimeo user videos group
https://vimeo.com/groups/189033
Facebook group
https://www.facebook.com/octaneforcinema4d
OBSOLETE VERSION:
Hi all,
new version 0.96 is here for testing. There is some improvements on code. Most important is ability for doing sub-frame motionblur.
Anymore we have a new control dialog. Which has all buttons and menu commands. Live Viewer window can be attached to this or some other window. Also some user friendly features. You can read the rest of implements from changes list.
Our current step will be fix possible problems with your reports. And start the final stage. Node editor is still wip and will delay to final stage.
And last words: i wish to thanks the all people who helps me on developments. Specially to CFrank(for endless testing), Beppe, Asyme1, Dinf, kirbyzz, Silverwing(for visual desing of info) and others.
Note: Please don't forget to check sample scenes and help files.
Version 0.96 for Windows (R12-R15) (TESTING ONLY)
http://render.otoy.com/customerdownload ... a-0.96.exe
Version 0.96 for Macosx (r13) (TESTING ONLY)
Version 0.96 for Macosx (r14) (TESTING ONLY)
Version 0.96 for Macosx (r15)
Not available, try the R14 version
Demo version 0.96 for Windows (R13-R15) (DEMO)
http://render.otoy.com/customerdownload ... 6-demo.exe
[/i]
changes since Beta 0.9.0
- improved Live Viewer and Picture Viewer render info display
- fixed closing the opened scenes problem
- moblur support(Nice for full rendering, be carrefull for incremental renderings)
- r15 support
- settings presets menu
- a "remove unused materials" command
- improved button for resulotion lock on Live Viewer
changes since Beta 0.8.8a
- revisions on Octane object presets
- New octane dialog
- transferred all render icons to octane dialog
- copy/paste octane settings
- copy octane settings to render settings
- added all controls of kernel/cameraimager/post to render settings
- octane render settings revised
changes since Beta 0.8.6d
- material preview size parameter for procedurals
Stabile version 1.01 (SDK 1.20.3) **** 17.01.14 ****
- Silverwing
- Contact:
Wow Aoktar!
You are a genius!
As far as I can see this is an absolute great release.
Of course you know me... first thing I have tested was the motion blur.
And what can I say. It works splendid! Even if you chance the camera´s shutter it reacts to that... simply brilliant!
Also of course I appreciate that you took my design as reference!
In my opinion its great and very neat and clear.
And the best thing is for those who might not like it. They can simply shut it off
I´m really impressed. Can´t say much about stability yet. But it did not crash once I opened it. (good thing)
So thanks a lot for your hard work. I can see it coming together to V1 very well!
I´m very happy right now!
Raphael
You are a genius!
Raphael
WIN 10 PRO 64 | ASUS X99-E WS | 3 X GTX 1080Ti | i7 5960X 8X 3,33GHz | 64GB RAM
Thanks to you Raphael,Silverwing wrote:Wow Aoktar!
You are a genius!
Raphael
Also for your great idea and design. I have tried to make similar. And i gave a functionality to left mouse click to show/hide the info. And I need your feedbacks to make better.
Ahmet Oktar
Octane For Cinema 4D Developper / 3d generalist
did you copied octane libs files to main folder? I don't suggest if you have not startup problems. And be sure removed all octane files before install. I found a older message has similar problem. It can be same.atilak wrote:bugs very seriously. No graphics card detected.
The problem is not changed by installing the latest drive.
Win 7 - i7 920. 24 gb ram
Geforce GTX 670
http://render.otoy.com/forum/viewtopic.php?f=30&t=35391
Hey Aoktar!
This looks great! Love the new on screen info. Nicely done. Very useful. And all these scenes to mess around with. Awesome. I think I'm going to be up pretty late tonight with this new toy.
Thanks!!
Alec
Thanks!!
Alec
Alec Syme
http://www.fuseanimation.com
-Gigabyte X79-UP4 - Intel i7 3930 3.4 - Windows 8.1 Pro 64bit - EVGA TITAN X7 - 32 Gigs Corsair 1600 4 channel RAM -
Hi Aoktar-
First quick bug report. I'm not able to close the new "GPU Info" box. I can minimize it, I can maximize it, I can even bring up another one, but it won't close.
Alec
Alec
Alec Syme
