invert falloff ?
Andygraph3D
Is it possible invert falloff ?
In my experience, a falloff is best used to feed the "amount" pin of a "mix" texture. So swapping texture1 and texture2 of the mix effectively inverts the falloff.
acc24ex
- hm.. good info..
- I tried using the invert texture node after the falloff node - yes it does that, but you have to change the settings of the falloff, you could probably try the color correction node, it has a invert setting as well
the one on the right is inverted
roeland
There are normal and grazing inputs on a falloff node (not sure if they are exposed in the plugin though), you can swap these two values.
Roeland
Hi Roeland - that's what I meant by texture1 and texture2 - they are in fact "normal" and "grazing" as you correctly point out - and they are available in the Poser plugin.
Return to “Poser”
