Stabile version 1.01 (SDK 1.20.3) **** 17.01.14 ****
inlifethrill
Here is a screen cast regarding the scaling issue I was referring to in my previous post.
inlife
dinf
... "stoprays at samplevalue x" tag ...
It would be yet a rendertime saver to be able to animate the scene wide sample counts if that tag couldn't be realised in time.
Also, as mentioned earlier, I would appreciate an info-overlay that is able to adapt the C4D font sizes. The overlay looks very good to my, but right now, with a font size of 16 the layout is completely shifted. That does not increase the readability of the info-overlay.
Greets & thanks.
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
djart: if i understand right that this is a optimization for Octane Core, not plugin.
dinf: to scale the info boxes is not easy, best is to fix the size of font.
inlifethrill: can't see your video
inlifethrill
Sorry about that. Just updated the link.
dinf
aoktar wrote:dinf: to scale the info boxes is not easy, best is to fix the size of font.
I can't change the font if I don't want to wear glasses for using Octane ;)
What do you think about animating the max samples value? Since scenes are sometimes uploaded completely, would this be possible?
I found another issue these days: when doing game content without using Octane, like exporting 3DS objects, there is always the hidden "myoctanesettings" as a polygonobject in the 3DS file. This causes ingame crashes or prohibits the game engine from loading or working. The only workaround I have in this case is to deactivate Octane, using plugin boss for that. Is it possible to deactivate this objcet only when working with non-Octane scenes?
inlifethrill:
i saw it, sure needs a fix for that
dinf:
is it for unity? I'll look for fixes if we need
check this page for a code to delete this object
http://render.otoy.com/forum/viewtopic. ... gs#p130577
For maxsamples look this:
dinf
aoktar wrote:dinf:
is it for unity?
No, Trackmania so I can't do anything inside the engine like in Unity. Thanks for the coffee script, I'PP try it :)
Oh, what? Great :) This is new to the 0.9x generation, right? I think I looked at an older version where these rendersettings are not included. Got a bit confused by different versions now ^^
dinf wrote:
aoktar wrote:dinf:
is it for unity?
Yes it's on 0.9x series. i'm getting close to final release.
And look this video for liveDB ;)
[vimeo]http://www.vimeo.com/79335989[/vimeo]
atome451
atome451 wrote:Hi,
I've found another issue with Hair.
The plugin is able to render Hair (as polygonal) since the first version i think but now it render only the number of guides, not the number of hair. I'm almost sure it wasn't the case before. Hope this wil help you.
EDIT : I work with C4D R14.
Sorry, I've understood my mistake. I obtained this result with a Hair object applied directly on a plane (not edited, without selection of polygones). This doesn't work with Octane.
A hair object with selection of polygones works as usual with Octane.
Sorry again.
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
a video for TeamRender support of R15. It seems smoothly working
[vimeo]http://www.vimeo.com/79464295[/vimeo]
