light emitting tv
miohn
sorry if this topic has been dicussed already.
Please, how can I make an animated luminance material
(TV Screen which lights the scene) with an image sequence applied?
thanks
Mike
absolutely,
look this and you'll see a example. Use c4d bitmap instead of octane imagetexture. for animated sequences
http://render.otoy.com/forum/viewtopic.php?f=30&t=36303
miohn
ahh thanks very much!
Mike
miohn
Hi aoktar,
works good so far!
But I got 2 problems with my tv:
1. when I add a second material with another anim-sequence to a second plane
(so 2 different TVs) - "only" one is rendering!
Either the second (with the second image sequence) is completely white
or isn't animating!
At least I need 4 different screens. Is there a workaround for this
or can Octane handle only "one"?
2. How can I make the emitting light stronger without overbrighten the image itself?
So that only the environment gets brighter.
thanks
Mike
i have checked for two animated images. It's ok. what is your version of plugin?
second question is for experts of octane. maybe need some trick to get better balance
miohn
the latest available here in the forum.
Its 0.96 (GTX Titan, Win7 64, Dual 2680v2, 64 GB Ram)
Any tips for my second question about the blown-out image?
thanks
Mike
miohn
I still have the problem, that I can only render "1" animated sequence.
Anyone else having this issue?
thanks
Mike
miohn wrote:Hi,
thanks
Mike
show me your texture names please.
miohn
Hi aoktar,
the jpeg image sequences are named as follow:
Film_1__00000 ...
Film_2__00000 ...
Film_3__00000 ...
Film_4__00000 ...
Every sequence works for its own, but not together.
thanks
Mike
try absolute paths as image, there is a problem on relatives
