sorry if this topic has been dicussed already.
Please, how can I make an animated luminance material
(TV Screen which lights the scene) with an image sequence applied?
thanks
Mike
light emitting tv
absolutely,
look this and you'll see a example. Use c4d bitmap instead of octane imagetexture. for animated sequences
http://render.otoy.com/forum/viewtopic.php?f=30&t=36303
Hi aoktar,
works good so far!
But I got 2 problems with my tv:
1. when I add a second material with another anim-sequence to a second plane
(so 2 different TVs) - "only" one is rendering!
Either the second (with the second image sequence) is completely white
or isn't animating!
At least I need 4 different screens. Is there a workaround for this
or can Octane handle only "one"?
2. How can I make the emitting light stronger without overbrighten the image itself?
So that only the environment gets brighter.
thanks
Mike
works good so far!
or isn't animating!
thanks
Mike
i have checked for two animated images. It's ok. what is your version of plugin?
second question is for experts of octane. maybe need some trick to get better balance
show me your texture names please.miohn wrote:Hi,
I still have the problem, that I can only render "1" animated sequence.
Anyone else having this issue?
thanks
Mike
try absolute paths as image, there is a problem on relatives
- cc.jpg (23.2 KiB) Viewed 6300 times
