Face cracking?
Moderator: BK
- rbennett2040
unfortunately because of the digits limit in the daz slider, you won't see the input number; as zero is below the limit the plugin won't accept it, but the 4 digits in the daz slider still show like it was zero... to overcome by this: http://render.otoy.com/forum/viewtopic.php?f=44&t=36713jimgale wrote:I've found that you have to specify a non-zero value and THEN specify a zero value for it to 'take' at the lowest value it can have.
„The obvious is that which is never seen until someone expresses it simply ‟
These cracks are transparent geometry, the upper looks like scalp, the lower like eyebrow, that cut through the geometry of the head.
Took me a good while to figure that out.
Scale the hair or use a deformer, and move the eyebrow geometry if thi is the case.
Hope that helps!
Hope that helps!
Intel i7 | 32gb | Win7pro-64
2 x Geforce GTX 660 ti/2gb +GTX 650 for display| Driver 310.90
DAZ Studio 4.5 Hexagon 2.5 Octane v1.11
