Live Viewer Vs Render
tegatwork
I've got a new problem, i'm sure that I'm missing something... but.. I need your help :)
Here's my problem : everything is ok while i'm working on my scene, in the live viewer. But when I'm launching the final render... the picture turns very bright, as you can see on the screenshot.
Any clue?
tegatwork
Well... I found a solution, but I'm still misunderstanding...
I changed my setting to pathtracing and everything was ok... then, i changed it back to Direct Light... and everything was still ok...
Am I running mad?
pokeit
I think this is the linear workflow thing I had so much fun with... render in 16bit in the picture viewer or update scene/textures to full Linear workflow. search forum for 'linear workflow'
Also check you're cam tag/cam imager if enabled it will overwrite the global cam settings
cheers
poke
2xI7 3930K 3.2ghz/32gig/Win10ultsp1 1xI7 6950X @4.0ghz 2x Titans 1x 780ti 3x 980ti
C4DR15 OctaneC4D 3.03.3 SDK 3.03.3 Mobo: AsusP9X79 Pro
tegatwork
Ok... Linear workflow will explode my files size :/
I'll try the 16 bits thing, and the "technic" i found with pathtracing / Direct Light.
Thanks a lot, I hope it will works fine (but i keep in mind the linear workflow thing, then).
do you have cameratag with enabled camera imager or is multipass enabled?
LFedit
I"m seeing similar behavior with white balance when using multipass, turning off multipass fixes the white balance issue. I'm using non-linear color.
Win 10, Threadripper Pro, Dual 3090s
did you read manual section which contains multipass and linear color usage?
davidtorpey
I am having the same problem.
I can't find anything about multipass in the manual. I also can't find the octane multipass setting in C4D.
Please help
here is the difference I am getting....
http://render.otoy.com/manuals/Cinema4D/?page_id=109
there is a short info but enough i think. Your viewed images will be brighter but it must seem correctly when you open in a editing program.
useruser
hi,
i had this strange issue too a couple of times. suddenly the final rendered image is much brighter and "washed out" as the preview in liveviewer.
my workaround is to copy the whole scene into a new projectfile. then there is no difference between the octane-liveviewer and the renderd picture in the picturemanager again.
Workstation: Win 10 PRO 64 bit, 3,4 GHZ ,6-cores, 64 GB RAM , 4x RTX 2080 Ti
1. RenderSlave: Win 10 Pro 64 bit , 3x GTX 980Ti
2. RenderSlave: Win 10 Pro 64 bit 2x GTX 980 Ti
