When are you going to release 1.20 version as 3dsMax plugin
boris
mbetke wrote:I hope we will see some more 3dsmax connections to Octane like Xref objects.
I clutter all my maxfiles with models I need to put into each scene. So instead having small .max files I go with 300+ MB files all the time.
Without the feature scene-management is really a pain.
hmm. xref objects and also scene working fine here. maybe i misunderstand your problem.
P6T7 WS SuperComputer / i7 980 @ 3.33GHz / 24 GB / 1500W + 1200W PSUs / 6x GTX 680 4 GB + 1x Tesla M2070 6GB (placeholder :))
Karba
gabrielefx wrote:architectural glass is the correct name
why you call it fake?
"fake" isn't a good word
It is fake.
Not real caustic, fake caustic. It just works fine in some cased like flat window glasses.
gabrielefx
ok I saw somewhere a test of architectural glass and caustics, a sort of mix between fake+real
is it possible to implement it?
Also I would like to see implemented a batch method to save passes.
When we do animations every time we have to render two times the job
A good way is to create a multilayer exr file if you don't want utilize the Max render passes method.
JuM
hehe i didnt knew you implemented all of them. Sorry did you add "Multi-threaded scene compilation" ?
mbetke
Yes it is in there for a longer time now.
PURE3D Visualisierungen
Return to “Autodesk 3Ds Max”
