Mac OS C4d plugin probs
kristoph
Keep getting this error message. See attached Cuda error.
Also having some serious performance probs. Render speed seems to be normal but very slow moving things around view port. Rotate, move etc. It feels like I dont have enough Ram but I have 32gb installed. Also running quadcore 3.4ghz with and 680mx 2GB.
Seems to be affecting other programs too.
Other issue is C4d keeps crashing when idle. See attached App error.
Anyone else having these issues?
Cheers
App Error
App Error
Cuda Error
Cuda Error
Mac Pro 5,1 Hexcore 3.33Mhz / Dual GTX 680 / 24GB Ram
C4D R14 / Octane 0.73 / SDK 1.2
about the navigation performance, if you have only one gpu for display and rendering, you need to activate the priority option in the octane setting, in this way octane leaves some gpu power for viewport navigation ;)
i'll check about the idle crash, maybe it's also related to the priority, there is not enough gpu power for other applications :roll:
ciao beppe
kristoph
Hi thanks for replying bepeg4d
See attached settings screen grab.
These are the settings Ive been running - which are the default – Should I be doing something different?
Even typing this reply is laggy! wtf!
Cheers
yes, you should try to activate the "use pri" checkbox at the right of the gpu, in this way you activate the priority option for that particular gpu and you could choose different priority with the popup ;)
ciao beppe
kristoph
thanks for the help mate appreciated :-)
very good, i'm happy to hear that the priority works, does it also solve the idle issue?
are you on imac or macbook pro?
ciao beppe
kristoph
Using an iMac.
The priority has solved the performance problem. Thanks for that :-)
Still having the crash when idle. Seems like its just me though. Weird.
i have to do some tests to see if i can reproduce the problem on my system :roll:
ciao beppe
what is the gpu memory status and texture usage while this crashes occured?
kristoph
Ill start monitoring the GPU and come back to you.
What do you mean by texture usage sorry?
