OctaneRender® for Maya® v1.16a beta [OBSOLETE]
Moderator: JimStar
Have tested and yes I also have this issue.
JimStar, rendering in the UI using the batch render command and verbose turned on simply outputs this
// Result: Rendering with OctaneRender®... //
// Result: Rendering Completed. See mayaRenderLog.txt for information. //
as renmaxhb has already stated.
I have also attached a txt file of the output from the command line in verbose mode. It doesn't really have any useful info either just an error statement that the render has failed.
T.
T.
- octane_v1.16a_batchRender_verboseOutput.zip
- (1.36 KiB) Downloaded 237 times
Win10 x64|i7-9750H 2.6 GHz|32 GB RAM | RTX2080 max Q 8GB
