OctaneRender® for Maya® v1.16a beta [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012, 2013 and 2013.5 / 32-bit & 64-bit on MS Windows operating systems.
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 279€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
  • Random crashes workaround.
DOWNLOAD
OctaneRender for Maya v1.16a beta (35.5MB autoinstaller file)
Yours,
The OctaneRender™ Team.
TBFX
Thanks JimStar,
Seems much more stable now. And thanks for the hard work and fast turnaround. I wasn't expecting updates in the middle of the night anymore, now that you are NZ based.
T.
renmaxhb
Thanks,JimStar,
but batchrender still can not work yet.
renmaxhb
TBFX
Do you test the batchrender?
TBFX
renmaxhb wrote:TBFX
Away from my workstation right now. Will give it a test later today.
T.
renmaxhb
JimStar,
can you a quick fix vesion ,the bacthrender can work,my project must render right now, please!
TT.
renmaxhb wrote:JimStar,
TT.
Please, can you give a more description of what does mean "can't work"? What do you do exactly, and what messages and behaviour you get, step by step?
renmaxhb
I test many times,any maya scences can not batchrender.
You can test a any simple bacthrender job.
renmaxhb
If run the bacthrender,maya show:// Result: Rendering Completed. See mayaRenderLog.txt for information,
In fact the plugin render nothing.
TBFX
Are you using the batch render command from within the Maya UI or the Render command from the command line? Have you tried both methods?
T.
Return to “Autodesk Maya”
