Preview of OctaneRender for Cinema 4D
Forums: Preview of OctaneRender for Cinema 4D
Re: Preview of OctaneRender for Cinema 4D
Postby buzby » Mon Apr 01, 2013 2:29 am
buzby Mon Apr 01, 2013 2:29 am
aoktar wrote: yes not very accurate, not in same concept. But livedb will come soon, also ocs exchange.
Aoktar, sorry if I am missing out I may no be up on all this, but livedb is already available, how will this effect C4D material conversion? What is OCS exchange?
Asrock z77 extreme9 | Intel i7 3770K 3.5 | Win 7 64 bit | (1) EVGA Titan| 30" Apple Cinema Display | LEPA G1600W PSU | 16GB Ram | Storm Trooper Case |
Autodesk Inventor>3DS Max >Cinema 4D R14 Broadcast
buzby
Postby aoktar » Mon Apr 01, 2013 12:21 pm
aoktar Mon Apr 01, 2013 12:21 pm
using of livedb not supported yet. This is not related for conversion but will give many samples for materials. Also we can have materials transfers between plugin/standalone.
Postby buzby » Mon Apr 01, 2013 5:31 pm
buzby Mon Apr 01, 2013 5:31 pm
alexmunteanu wrote:From Materials window: Create->Shader->C4dOctane
Thank you
buzby
Postby buzby » Mon Apr 08, 2013 9:15 pm
buzby Mon Apr 08, 2013 9:15 pm
Aoktar, can you tell me more about the materials transfers between plugin/standalone?
I purchased this plugin so I could use Octane within C4D, I thought the purpose of the plugin was going to be the added benefit of being able to use all the native materials and lighting within C4d (you may never have said this it is just what I assumed). Is this plugin more of a convenience of not having to switch back and forth between the Octane export plugin that we have been using in the past with OctaneRender standalone, or is this ever going to work natively within C4D using all of C4D's materials and lighting as it matures?
buzby
Postby aoktar » Mon Apr 08, 2013 9:36 pm
aoktar Mon Apr 08, 2013 9:36 pm
you can do everything in c4d like standalone. Standart materials support actually is limited matched texture nodes. It works with standart materials which has textures, falloff. i'm adding a shader to texture convertion option on development version. Also material db and export/import materials will be available on the next releases.
I can send additional commercial sample scenes to you
Postby buzby » Mon Apr 08, 2013 9:48 pm
buzby Mon Apr 08, 2013 9:48 pm
aoktar wrote:you can do everything in c4d like standalone. Standart materials support actually is limited matched texture nodes. It works with standart materials which has textures, falloff. i'm adding a shader to texture convertion option on development version. Also material db and export/import materials will be available on the next releases.
Sounds great thank you! Yes please do drop them in this thread or you can PM me
buzby
Postby aoktar » Mon Apr 08, 2013 9:59 pm
aoktar Mon Apr 08, 2013 9:59 pm
when i prepared for sending, i'm going to send them. in a 1-2 days. ok?
Postby buzby » Tue Apr 09, 2013 12:32 am
buzby Tue Apr 09, 2013 12:32 am
Yes thanks you
buzby
Postby TonyBoy » Thu May 02, 2013 3:33 pm
TonyBoy Thu May 02, 2013 3:33 pm
I know Aoktar is working away at the C4D edition but I miss the updates to his progress. I am anxious to astonish the folks at C4D Cafe with my very fast animation renders (especially those who have expressed skepticism on the whole issue of GPU rendering). Any teasers, Aoktar (and an early congratulations on your future contribution to the rapidly growing Turkish economy!)?
TonyBoy
Previous
Users browsing this forum: Google [Bot] and 3 guests
Sun Jul 12, 2020 8:25 pm [ UTC ]
