Hi Paul,face_off wrote:I tried batch rendering in ArchiCAD (via setting the View "Generate In" to "Photorender Window", and then setting all the views to shortcuts to publishing set - as per http://www.youtube.com/watch?v=tluXEVPayYI), however when I publish the set, it changes the Photorenderer from "OctaneRender Renderer" back to "Internal Renderer". Is this an ArchiCAD bug?
I got the batch render working perfectly.
you can see my workflow, maybe you can spot something you are doing different?
cheers, Jeroen
